Home > Puma (Tdci) > white dial kit - removal?
Gasket
Hi folks.
Can I check if anyone has fitted a white dial kit? - for example https://tmdtuning.com/shop/tmd-white-dials/.
Looking at a puma with one fitted and would prefer to return to stock. Was wondering if it is simply an overlay (in which case could I simply remove it to expose the original dials) or if it would mean tracking down an original piece (which I can't seem to find as a separate part number on Microcat).
Thank you!
Post #834415 31st May 2020 12:50pm
Stiff1
My understanding is that they are a whole new set, you have to remove the needles.
Your best bet would be to swap with another member who wanted white ones. I imagine there would be a fair bit of interest
Post #834625 1st Jun 2020 5:33pm
bear100
Found this one on EBay £55
I prefer the black tbh 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #834660 1st Jun 2020 7:52pm
Sulisuli
Have sent you a pm Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #834666 1st Jun 2020 8:23pm
Gasket
...and replied Smile
Think I'll be taking the advice above an offering it as a free swap to another forumer.
Does anyone happen to know if the original dial view was common across all Puma Defenders?
I ask as the dealer has a few and I could try and make it a condition of the sale that its swapped over - the only issue being that the other models are higher spec with Traction Control as standard. I didn't know whether all Puma dashes had the same TC illumination and if it only works on those with it fitted.
Post #834774 2nd Jun 2020 1:01pm
Gasket
Do you couldn't find it on eBay - doe you have a link by any chance? My eyesight isn't good enough to see if its a genuine one or a black aftermarket one.
Post #834775 2nd Jun 2020 1:07pm
Martin
Site Admin
There are 3 facia specs, ignoring the obvious MPH/KPH calibrated speedo difference.
A. With 1 TC light (all 2.4 Pumas)
B. With 1 TC light and DPF lights (2.2 Pumas up to 14MY)
C. With TC and TC off lights and DPF lights (2.2 Pumas 15MY-16MY)
The instrument pack (and the facia) is the same with or without ABS/TC.
You can replace with a facia from a newer spec (e.g. replace A with A, B or C; or B with B or C). The additional warning lights don't clash or replace lamps on earlier models.
The TC off lamp on 15-16MY is in the position which is a park brake symbol (P) on pre-15MY Defenders but it never lights up.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #834785 2nd Jun 2020 2:34pm
Gasket
Martin - that's just what I needed, thank you very much once again!
Post #834801 2nd Jun 2020 4:08pm
bear100
If you type into Ebay defender dials theres lots on there to choose from as martin kindly pointed out.
lockwood seems to pop up quite a bit
Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #834815 2nd Jun 2020 6:09pm
Martin
Site Admin
FYI you can't swap a Disco 3/RRS 1/Freelander 2 facia in as the speedo is calibrated differently and the lamps are in different places.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #834818 2nd Jun 2020 6:18pm
