Home > Puma (Tdci) > white dial kit - removal? |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Hi folks.
Can I check if anyone has fitted a white dial kit? - for example https://tmdtuning.com/shop/tmd-white-dials/. Looking at a puma with one fitted and would prefer to return to stock. Was wondering if it is simply an overlay (in which case could I simply remove it to expose the original dials) or if it would mean tracking down an original piece (which I can't seem to find as a separate part number on Microcat). Thank you! |
31st May 2020 12:50pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1867 |
Click image to enlarge Found this one on EBay £55 I prefer the black tbh 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
1st Jun 2020 7:52pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Have sent you a pm 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
1st Jun 2020 8:23pm |
...and replied
Think I'll be taking the advice above an offering it as a free swap to another forumer. Does anyone happen to know if the original dial view was common across all Puma Defenders? I ask as the dealer has a few and I could try and make it a condition of the sale that its swapped over - the only issue being that the other models are higher spec with Traction Control as standard. I didn't know whether all Puma dashes had the same TC illumination and if it only works on those with it fitted. |
2nd Jun 2020 1:01pm |
Do you couldn't find it on eBay - doe you have a link by any chance? My eyesight isn't good enough to see if its a genuine one or a black aftermarket one. |
2nd Jun 2020 1:07pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6480 |
There are 3 facia specs, ignoring the obvious MPH/KPH calibrated speedo difference.
A. With 1 TC light (all 2.4 Pumas) B. With 1 TC light and DPF lights (2.2 Pumas up to 14MY) C. With TC and TC off lights and DPF lights (2.2 Pumas 15MY-16MY) The instrument pack (and the facia) is the same with or without ABS/TC. You can replace with a facia from a newer spec (e.g. replace A with A, B or C; or B with B or C). The additional warning lights don't clash or replace lamps on earlier models. The TC off lamp on 15-16MY is in the position which is a park brake symbol (P) on pre-15MY Defenders but it never lights up. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Jun 2020 2:34pm |
Martin - that's just what I needed, thank you very much once again!
2nd Jun 2020 4:08pm |
If you type into Ebay defender dials theres lots on there to choose from as martin kindly pointed out.
lockwood seems to pop up quite a bit 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
2nd Jun 2020 6:09pm |
FYI you can't swap a Disco 3/RRS 1/Freelander 2 facia in as the speedo is calibrated differently and the lamps are in different places. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Jun 2020 6:18pm |
