Home > Maintenance & Modifications > Alternative side lights and indicators non LED
Page 2 of 2 <12
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
OOOOOOOOOOOOOOOOOOh I wish I hadn't had the idea of fitting NAS lights. S.H.M.B.O. wanted to know what I was doing looking at new land rover lights, I explained why and the reply was ," well they are not going to be brighter so they are not going to be seen any better, why don't you put brighter lights on?". Point taken.
I will go and put my head in he sand again, what alternative do I have, I don't what problem with the caravan lights if I fit LED's to the 110 and the caravan has filament bulbs. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #828651 30th Apr 2020 12:14pm
Martin
Site Admin
NAS lights are so much brighter than the standard ones, they have 2¼ times the surface area of the standard ones.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #828653 30th Apr 2020 12:18pm
ARC99
Well I can finally put this idea back were it belongs, in the rubbish file. I managed to find an old /cracked plinth, cut off the studs and lined up the hole in the body for the stop/tail light with the plinth and as suggested the plinth over hangs the body and S.H.M.B.O. has said NO to cutting into the body to open up the hole. So its staying with standard lights I may have a look round to see if I can get LED bulbs to replace the filament bulbs . Don't make old people mad.
Richard
Post #830846 13th May 2020 11:36am
ChrisDefender
Hi Richard,
After great advice from LRA on here I bought a set of these (link below), LED bulbs that directly replace the standard Stop/Brake tail lights on my Puma.
They look spot on, orignial looks on the outside and much better lights on the inner. I also got the ones for the front side lights too and again, much better.
https://www.classiccarleds.co.uk/products/...tive-earth
Hope that might help.
Post #830850 13th May 2020 11:45am
ARC99
ChrisDefender.
Thanks for the link, I'll check with them to see if they do replacements for indicators and front side lights. Don't make old people mad.
Richard
Post #830857 13th May 2020 11:56am
ChrisDefender
Hi Richard,
These are what I put in my front side lights. They are a really white light, I like it. For the cost of them you can't go wrong really!
https://www.classiccarleds.co.uk/products/...et-fitting
I haven't done the indicators I'm araid.
Post #830858 13th May 2020 12:05pm
ARC99
Well I thought that I had finished with the subject of replacing the original set up with LED's and decided to stick with filament bulbs well I was wrong.
Yesterday it got round to the daily opening of boxes that were delivered 3 days ago, we don't open anything unless it has been in isolation for 3 days,. I came across a box with my delivery details and upon opening it found a set of 73mm LED replacement lights, figuring I must has somehow forgotten I had ordered them I checked my emails for confirmation of the order= nothing, checked my online banking for something that looked familiar = nothing. then S.W.M.B.O. asked why I looked so puzzled and I told her expecting the usual "spending money again" only for her to smile say "oh good they have arrived Shocked Shocked needed a drink after that.
Having fitted the easy one's ,side lights, what a difference, I now have the slightly tricky job of the indicators.
Question After listening for the "click" of the relay I have come to the conclusion that me hearing is on its way out as I cannot pin point the indicator relay. I am right in thinking it's on the top roe and first one on the left? . Don't make old people mad.
Richard
Post #832837 23rd May 2020 11:17am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Fitted clear NAS lights with coloured bulbs/LEDs to mine Thumbs Up
Post #832838 23rd May 2020 11:21am
ARC99
To put this to bed finally.
All finished with no drama's with the exception of one rear indicator not working and that was my fault in my excitement I hadn't made sure that the connectors clicked together, two minutes with the screwdriver and all was made good. Just have to sort out trailer confirmation flash when I get the caravan hooked up in the future. Don't make old people mad.
Richard
Post #833022 24th May 2020 10:04am
Page 2 of 2 <12
