Home > Td5 > Air intake modificaion |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2073 |
102mm pipe. Removed the impeller thing out the airbox too
Click image to enlarge Click image to enlarge Instagram @defender_ventures Empire Tuning - Agent |
18th Apr 2020 1:58pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 755 |
Looks good- Keep looking at doing similar with ours.
Have you had any issues with drawing water into the intake? Regards Chris |
18th Apr 2020 2:04pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
I used that 3" pipe on my Td5 (although I'm a bit concerned where the jubilee clips tighten up on the ends... looks like it may tear the rubber between the metal coils)
Anyway, with a 3" snorkel now and the impellor fan thing removed from my air box, I can really tell it breathes better. Not had chance to take it for a good run yet. |
18th Apr 2020 2:08pm |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 |
Good stuff! Im either thinking about 90mm or 102mm. Does anyone know if 90mm will fit under the steering column?
How much pipe did you need Bankz? Yes I have removed that from the airbox also. Instagram - @Land_Rover_Defender |
18th Apr 2020 2:10pm |
Big snorkel fitted, never noticed any.
Used roughly 1m biggest you can fit under the steeri column is 3" however it does rub so I ended up making a plastic sheath that cover the intske pipe and prevented wear. As you can see my larger 102mm intake runs to the wing top now. The pipe work is also siliconed at each end so fully sealed. Instagram @defender_ventures Empire Tuning - Agent |
18th Apr 2020 2:11pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 862 |
Been quite a few threads on this recently and im starting to become interested however i dont really want a RAI. I was wondering if itd be ok to have the wintop intake and cut it off just after the 90 degree bend. Im not sure how odd looking that would be.
18th Apr 2020 2:49pm |
Been looking at mine again. Just trying to work out where to run the pipework. 102mm cant really go anywhere else other than behind the wing bracket and then over the engine cover. But Bankz I have seen that you managed to squeeze yours down the side next to the brake servo and engine. Instagram - @Land_Rover_Defender
18th Apr 2020 5:50pm |
Indeed. Acoustic cover off and forced it in. Sat happy afterthat Instagram @defender_ventures
18th Apr 2020 6:13pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
I was thinking how tiny the piping is from my safari snorkel to airbox while taking things apart the other day. Might take it out for a run without any piping on, see how different it is.
18th Apr 2020 7:47pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2163 |
Want to do the mod to my 2.2 puma. The above info seems to identify TD5 so is there any info for the puma job thanks. Also is it a 102mm flexi from the wing to filter box?
Cheers Keith |
18th Apr 2020 8:37pm |
The arrangement on a Puma is slightly different but there is a kit available from Nugget Stuff. Have a search on that name and it'll find recent threads discussing it.
On a stock Puma in particular, it's a very worthwhile mod as the air intake pipework is particularly restrictive. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
18th Apr 2020 9:02pm |
Thank a lot. Just sent Pete Bell a message asking if he has a silicone pipe to turbo and if any difference shown. Is it the same internal air box propeller to come out as in previous threads cheers
Keith |
18th Apr 2020 9:10pm |
Essentially, yes. Darren
18th Apr 2020 9:22pm |
Just wondering how much difference 102mm would make compared to 76mm for example. If you arent running an upgraded turbo. Instagram - @Land_Rover_Defender
19th Apr 2020 12:12am |
