Home > Td5 > Air intake modificaion
Page 2 of 2 <12
Greeny
Fitted mine this weekend. Went with a 76mm 2ply silicone hose from ASH and then purchased a revotec outlet for the wing. See pictures below, very straightforward as it fits nicely under the steering column. It might be a squeeze if you have ABS however. To fit it at the wing I used the original casing, drilled a 76mm hole and just placed the revotec outlet in and secured it with some self tappers. I also fitted some gauze to the bottom of the outlet where the original pipe work goes, this will allow water to drain out and also prevent things from being sucked in. All in it cost £30.
There are definitely performance increases since fitting it and noise increases. Waiting for mine to be remapped now with all the bits added.
 Instagram - @Land_Rover_Defender
Post #827884 26th Apr 2020 11:12pm
Ingenius and very neat. Darren
Post #827909 27th Apr 2020 8:13am
Page 2 of 2 <12
