Home > Off Topic > Long reach hedge trimmers - anyone recommend a good one?
Pat
Wales
Recommendations for a decent long reach or telescopic hedge trimmer appreciated.
My son has moved to a place with 8ft high neglected mixed (holly, hawthorn, etc.) hedging that needs reclaiming ... and I've been volunteered! It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now?
It's not a car, it's a way of life!
Post #825638 15th Apr 2020 9:45pm
X4SKP
Hello Pat
I've been through three of these over the past 2 decades and ended up with one of these...
https://www.frjonesandson.co.uk/products/s...LkEALw_wcB
It's no coincidence that most professional tree surgeons / garden services Co. all appear to turn up with
'the orange kit' Exclamation
Really can't fault my chain saw and two hedge trimmers... SKIP
Post #825646 15th Apr 2020 10:01pm
Bluest
Don’t be tempted by the Screwfix Titan cheapy ones. The fuel pipes rot a way in a few months and now the clutch drags and squeals away on tick over. Remarkably, it does start very easily though. 2007 110 TDCi Station Wagon XS
Post #825650 15th Apr 2020 10:09pm
Stihl KM130R or I think there is a KM131 now too with multi angle hedge trimmer attachment and they have a split shaft for different uses.
They are NOT cheap though, if it's a one off job and you have no other use it might pay to get someone to do the job for you though.
Powerful machine, does a great job. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #825657 15th Apr 2020 10:20pm
Sulisuli
If it’s a one off perhaps a hire company maybe a cheaper option for you Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #825659 15th Apr 2020 10:28pm
Zed
It's obviously down to personal preference but if the hedge is only 8ft and very neglected I wouldn't recommend a long reach trimmer. It will be easier using a platform type ladder and a hedge trimmer with a longish blade. 600-750mm. You may also need loppers and/or a pruning saw.
Petrol machines from Echo, Stihl, Husqvarna are all decent. However they are pricey and may not make financial sense unless you use it a lot. If that is the case then get in a professional to renovate the hedge and once it's under control you can maintain it with a cheap/borrowed/hired regular or extended trimmer. WARNING.
Post #825661 15th Apr 2020 10:37pm
jst
I am a husky man if I can be for garden kit. Ideally xp kit!
But two exceptions I have are top handle saw and long reach pole saw. Botha re sthil. In case of long reach pole saw km131 4 stroke head unit with saw attachment.
It depends how much use it's going to get to warrant the purchase.
Echo are also gaining a good reputation might be worth a look. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #825663 15th Apr 2020 10:39pm
jst
Or mini tower, silky and std hedge cutter. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #825664 15th Apr 2020 10:40pm
Rashers
Can I suggest that if you have any petrol garden tools like hedge trimmers which oftenget laid up for months on end, to use a petrol additive to prevent the unleaded becoming stale.
I had a mate who worked as a horticultural engineer. He swore by a product called Aspen. I was not convinced, but I started using it in my brush cutter and hedge trimmer - both of which can go weeks without being started. For the first time ever I can go to either, especially at the start of the cutting season, and both will start without any issues.
It is quite pricey - around £20 for five litres. They do a 2 stroke and 4 stroke version and the 2 stroke is just like buying premix petrol / oil. Neither machine smokes as badly either. It is also allegedly better for fuel pipes which prevents them from rotting.
I can’t afford to use this stuff in my lawn mowers - it would bankrupt me - so I use B3 Ethenol Shield which I add a small amount to a tank of unleaded. Again, never had an issue with the mower failing to start at the start of the season.
I believe Briggs and Stratton do a similar two stroke oil product with the additive.
Getting back to the post, the orange stuff is the best, but not as good as it once was. That came from my tree surgeon who over the years has witnessed having to replace his kit more regularly! It is good, but if you only have a small hedge, a lot of expense. I personally would hire the kit in.
Post #825714 16th Apr 2020 8:20am
Stihl also do an Aspen equivalent. For occasional users it is fantastic due to its much longer shelf (or tank) life.
Post #825725 16th Apr 2020 8:39am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I have been using a Stihl Combi machine for a good ten years now, with hedge trimmer, pruning saw, strimmer attachments. It is a brilliant muti-purpose piece of kit . Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #825737 16th Apr 2020 9:09am
gcc130
+1 for the Stihl Combi, I’ve had one for work for many years with hedgecutter, pruning saw and strummer attachments.
I also have the 1m extension tube, which is ok for the odd branch but it makes it very heavy and unwieldy to use for any length of time.
Post #825742 16th Apr 2020 9:26am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I'd normally suggest Stihl for everything but having recently moved house and wanting to get some jobs done in the garden despite my tools being in storage 60 miles away, I opted for one of these and it was delivered 3 days later.
https://www.aldi.co.uk/5-in-1-petrol-garde...1331010200
I figured for £130 and reading the generally positive reviews, you can't go too far wrong. The strimmer/brush cutter is a bit mickey mouse but for light garden work it should be grand. The lopper attachment also comes with an additional extension and it's got a 3 year warranty if it does fall to pieces.
Not yet had a chance to test it in anger but will provide an update over the weekend Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #825749 16th Apr 2020 9:41am
Rashers
3 year warranty, you are laughing! Aldi are pretty good with returns as well.
The good thing about Stihl and Husqvarna is in years to come you should be able to buy replacement parts and repair kits whereas the cheaper end of the market, you need to be finding a recycling centre.
Mitox is another brand at the bargain end of the market who make quite good stuff for domestic use.
Post #825757 16th Apr 2020 9:55am
hank
I too am a Husqvarna guy. Last summer I bought a Husqvarna 525lk Combi so that just the one power head can run a variety of attachments. So far I have a long reach multi angle hedge cutter and a garden strimmer. May Also get the pole saw.
Absolutely faultless. Powerful, balanced, lightweight and competitively priced.
Also have nothing but good things to say about my Husqvarna 560XP chainsaw
But if you are an occasional user may be better to hire it... Then again there are often good buys on the used market, which you could then gift to your son and hey presto you are off the hook for future prunings! > 110 XS Double Cab
Post #825759 16th Apr 2020 10:12am
