| sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145
Love the tan leather inserts on the interior
| AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1373
Whilst dredging the ditch at back of my house I got bogged down. In my haste to get it done I asked the wife to pull me out. Which resorted in a bent bumper.
New bumper fitted today Click image to enlarge Click image to enlarge Click image to enlarge |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18047
Has the bumper actually ripped off the lower mounting on the offside chassis leg?
What were you pulling with, and did you snatch? |
Yes it ripped on bottom bracket. We’re the tapped plate is.
Used a kinetic recovery strap and did snatch yeah. Like I say, my own fault for doing it so hastily |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Good on you for sharing
I am sure that a salutary lesson about forces generated during recovery has been learned. At least that failure mode didn't result in a projectile through the rear of the Disco.
I've never actually seen a winch bumper fail in that way before. It's actually quite a sensible progressive failure mechanism, and I wonder if that is by design or just luck. Is/was there any bracing from the bottom of the winch tray back to the chassis? I presume not. |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I've always wondered about 'heavy duty' bumpers with recovery points that just rely on the end of chassis brackets
Now, yes there should be. But I never fit it mostly because it wasn’t compatible with the steering guard. However since this has happened I am going to fit them and modify them accordingly. It will give a 6 bolt connection for bumper to chassis as opposed to just 4 |
Aha, and now you know why they are supplied!
The only positive thing to take away is that there are so many ways that this could have been far, far, worse. As it is the only thing that took a hit is your wallet! |
| Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 732
Where is the bumper from AJC? It looks really smart
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
What did you get tugged with ? Surely not just the Mrs on the end of the rope?
| CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1913
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Looks smart but is a bit bendy! |
| All times are GMT |
