Home > Maintenance & Modifications > Replacement lights
stephan123
Replacement lights
Currently have Wipac LED side/repeater lights fitted at the front but want to revert back to the original look whilst keeping the bright LEDs. Any suggestions?
Post #823707 6th Apr 2020 5:13pm
There are a couple of options: if you can get them, fit River Runner 70mm LED light units or fit LED bulbs to standard light units. There are a whole range of opinions available about the legality of the latter but take a look at Classic Car LED's for some very nice replacements and have a search on here for some feedback. Darren
Post #823756 6th Apr 2020 8:40pm
stephan123
Cheers Darren!
Post #823759 6th Apr 2020 8:52pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I have the classic car LED's and they are outstanding.
There is a thread on them on here so the search function should bring it up.
Post #823781 6th Apr 2020 9:42pm
stephan123
Just had a peruse of their website and options seem to be endless. Not too clued up on amps and volts so was hoping you could advise on the ones you fitted to your truck. Many thanks!
Post #823803 6th Apr 2020 10:49pm
Danny Fireblade
I got these
https://www.classiccarleds.co.uk/collectio...9030763615
I also got new wipac crystals but I am sure they would work with any headlamp units with the same results.
Post #823805 6th Apr 2020 10:56pm
I think the OP was asking about sidelights not headlights.
I fitted these at the front after doing my headlights because my original sidelight looked so yellow and feeble.
https://www.classiccarleds.co.uk/products/...et-fitting
Post #823814 7th Apr 2020 6:56am
I fitted the same to mine, for the same reason Laughing
 Darren
Post #823821 7th Apr 2020 7:58am
VVS210
I put LED bulbs in standard light units when I had mine, got them from Advanced Factors (site sponsor?), worked a treat!
Post #823831 7th Apr 2020 9:03am
X4SKP
Hello stephan123
I wanted to do the same, up the 'light quality' but keep a standard look, so I bought X4 of these (X2 as Spares)
all 3 years ago and the original 2 are still OK.
http://www.ebay.co.uk/itm/Land-Rover-Defen...rmvSB=true
This was a bit of a trial for me, but I really didn't like the yellowed / warm look of the originals alongside of a decent
main headlight bulb, I know there are compliant issues for some but even raising this with my MOT Station all was OK.
Good Luck SKIP
Post #823844 7th Apr 2020 10:12am
ChrisDefender
Hi Blackwolf/LRA,
Maybe a silly question, but for a 2011 2.4 Puma are these simply just a straight swap with no adjustments needed to the wiring etc? Is it the 'Negative Earth' option we need for the sidelights.
I am running Wipac for the main headlights. If so, that's excellent! Bow down
Post #823861 7th Apr 2020 11:51am
Yes, just fit them in place of the old bulbs in exactly the same way as a normal bulb. Negative earth is what you need.
Post #823866 7th Apr 2020 12:43pm
ChrisDefender
Hi Blackwolf,
Thank you very much, I find all these light options very confusing! Laughing
Post #823867 7th Apr 2020 12:44pm
I know what you mean, far too many choices now! In the old days it was so simple....
Post #823872 7th Apr 2020 1:37pm
stephan123
X4SKP wrote:
Hello stephan123
Good Luck
Thanks Skip! Do they also come in amber? I woud rather keep stick with clear lenses for the front indicators. Many thanks
Post #824400 10th Apr 2020 2:35pm
