![]() | Home > Maintenance & Modifications > Filling in rivet holes |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1854 ![]() ![]() ![]() |
Easiest would be short Adel pop rivets and paint over it is a Land Rover after all!
Otherwise countersink and set a soft alloy solid rivet in place, rub down and surface finish the top & paint. HTH Keith |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 ![]() ![]() ![]() |
Thanks ickle the latter sounds like a good bet as it'll need painting anyway
![]() 1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold ![]() 1985 Land Rover 110 ex mod project Tithonus ~ Sold ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17783 ![]() ![]() ![]() |
TIG weld them. Have you seen the bonnet and holes? Most bonnet mounts also require some large holes so it may be more than just rivets.
Sorry I should've clarified, I want the one made to be fitted with a spare wheel carrier as I plan to fit one back to the bonnet so the holes for that are not a problem, just the tiny ones from the chequer plate as Id prefer the bonnet without it. 1999 Land Rover Defender 110 td5 station wagon
Ah, sorry, I misunderstood, it's the chequerplate holes!
I'd still try to TIG weld then grind smooth. |
That sounds a lot easier to be fair, will have to see about borrowing a welder then! 1999 Land Rover Defender 110 td5 station wagon
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
A really low tech approach would be to glue (Sikaflex/Tigerseal) some small pieces of ali under each hole and then fill and paint. Darren
A very low tech aproach indeed, would there be the risk of them falling off with all the viabration and heating/cooling? 1999 Land Rover Defender 110 td5 station wagon
No, shouldn't do with one of those sorts of adhesives. Darren
Cool will look into that also then when this new bonnet comes
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 663 ![]() ![]() ![]() |
Also known as a complete bodge. |
This is how not to bodge it. Rear tub chequerplate removal.
![]() Click image to enlarge ![]() Click image to enlarge |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Or a perfectly functional bush fix for someone who has neither the kit to TIG weld themselves or the opportunity/funds to take it to someone to weld it for them ![]() |
Thanks for that. Not everybody has access to a tig welder
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
