![]() | Home > In Car Electronics > Battery Charger connector |
How about a Hella socket? Much more robust than a cig. lighter one and rated at 10amps. With an appropriate fuse in line, could also double as a permanent live power point. Darren
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I use a CTEK maintainer on my motorbike (which has a factory fitted hella socket by the ignition barrel) and it works great.
I used the supplied battery fly leads, cut off the ring terminals and wired it into a hella plug. As LRA suggests, much stronger than the CTEK connector and useful for other things (tyre pump in my case) ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
If you go with the CTEK plug: their "comfort indicator panel" snaps into a Carling switch bezel, which might look good if you have some Carlings.
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
yep as above, get the CTEK panel - can be had for less than£20
![]() Click image to enlarge Or you could get the 13 pin towing socket adaptor from Martin of this forum. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
https://www.defender2.net/shop/tow-electri...c-p45.html
![]() Click image to enlarge ![]() ![]() ![]() |
mark13 Member Since: 16 Apr 2018 Location: Essex Posts: 56 ![]() ![]() ![]() |
No I’m stuck, I ordered a panel mount Ctek adapter (I had never seen them before) but then saw the 13 pin towering socket cable reply which I do like the idea of...... hmm the choices, I’m a bloke I don’t do choices!
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1254 ![]() ![]() |
This thread is good timing for me as I am assembling a few ctek bits to do something similar. I now have the dash mount connector but I intend to fit it to the outside of my 110. Reason, I do not want a cable through the door. I have the 'trailing' socket fitted to my series one which just tucks behind the grill and seems waterproof. Looking at the dash mount I have seen examples on boats motorbikes and quad bikes so Im sure its going to be ok. Que drill this weekend....... 1984 One-Ten CSW
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
I use the 13 pin tow plug as suggested by Martin. I originally toyed with the idea of fitting a Ctek panel but didn't like the thought of cutting a hole somewhere in my Defender. (there's enough corrosion inherited from Lode Lane without me adding to it
![]() Mini Countryman Cooper S Morgan Plus 8 |
I did mention Martin's socket in my post....however, for that you work you must have a 13 pin towing socket or a 7 pin with battery connection (12S) - the older 7 pin (12N) sockets do not connect to the battery. |
If like me you have the 7 pin 12N towing socket installed, easy to add the 12S to the truck. The genuine from Land Rover is very good quality. Easiest option to connect the Ctek, no need to even unlock the truck.
Eric ![]() Click image to enlarge ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3643 ![]() ![]() ![]() |
As I expect has happened to others on here, my Puma chirped as I started it on Saturday.
I really like the idea of one of Martin's adaptors. The 12S Socket looks good. I had a 13 pin on my last Focus and I have to say, I always thought it felt a better connection than the 12N's I had on other vehicles. My point is, how difficult is it to install the 12S or the 13 pin socket? ericvv has a genuine LR 12S (I like that idea as my truck is just about stock), do LR do 13 pin kits as well? Also, any recommendations for which Ctec charger for continual charging the truck? |
Re your last question, the CTEK MXS 5.0 should be more than adequate
More powerful ones will charge it faster, but that is not necessarily a good thing. |
Thanks kmac
![]() I have seen that Duckworth's do both the Sockets as LR branded. Just interested to know is it a plug and play or is it a bit more involved? I have a 2014 Puma 110 Utility |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
I use the plug that cane with mine, handy LEDs on there too.
It just lives under the seat ![]() Click image to enlarge 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
