|  | Home > Td5 > Socket for hub nut |
| Rich1968 Member Since: 03 Nov 2013 Location: Towcester Posts: 87    |
 Hi all
 Im doing the swivels and need to buy a 52mm socket. Can anyone recommend one that is deep enough and also cheap? Thanks Rich | ||
|  28th Mar 2020 10:52pm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060    | eBay and about £12    https://rover.ebay.com/rover/0/0/0?mpre=ht...2910677052 | ||
|  28th Mar 2020 11:11pm |
| benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361      | I would personally go for a box type one as my 52mm impact type like pictured above is not deep enough to get onto the inner locknut on my 90 when doing wheel bearings.
 In the end I now have both, which are both useful for different things. https://www.amazon.co.uk/Sealey-SX011-Hub-...amp;sr=8-1 Insta: @thebenjordan4x4 | ||
|  29th Mar 2020 7:50am |
 Thanks both. Not sure Id get the required 150 ft lb torque required with the box type? | ||
|  29th Mar 2020 8:32am |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058      | Convert your hubs to the superior two nut system! | ||
|  29th Mar 2020 9:04am |
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 927      | https://www.britpart.com/all-parts/da1118
 Have used and abused my britpart 52mm deep socket according to my records I brought it on the 26th November 2010  (can you tell I'm bored and back through the landy invoices)  Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest | ||
|  29th Mar 2020 9:10am |
| donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1917    |
 Definitely this. The replacement rear axle on my car came with the newer set up of spacer and the nut torqued up to 'daftNm'. Having studied and digested various threads on the topic, I decided to ditch the spacer and go old-style when doing some other rear axle stuff recently. I'm familiar with this from the umpty-um times I've done trailer bearings, and it's so much easier to manage. I'm lucky though in that I have a good impact driver, which took the 250Nm hub nut off without any drama. Luck, or planning ahead..... maybe.... can't remember. As with benniferJ I have the impact socket and the tube spanner. I know which I'd pick up first - I didn't have any issues getting the socket to fit onto the inner hub nut. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... | ||
|  29th Mar 2020 9:52am |
| Posting Rules
