Home > Td5 > Socket for hub nut
Rich1968
Socket for hub nut
Hi all
Im doing the swivels and need to buy a 52mm socket.
Can anyone recommend one that is deep enough and also cheap?
Thanks
Rich
Post #821914 28th Mar 2020 11:52pm
landy andy
Post #821917 29th Mar 2020 12:11am
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I would personally go for a box type one as my 52mm impact type like pictured above is not deep enough to get onto the inner locknut on my 90 when doing wheel bearings.
In the end I now have both, which are both useful for different things.
https://www.amazon.co.uk/Sealey-SX011-Hub-...amp;sr=8-1 Insta: @thebenjordan4x4
Post #821945 29th Mar 2020 8:50am
Rich1968
landy andy wrote:
eBay and about £12 Thumbs Up
https://rover.ebay.com/rover/0/0/0?mpre=ht...2910677052
Thanks both.
Not sure Id get the required 150 ft lb torque required with the box type?
Post #821956 29th Mar 2020 9:32am
Convert your hubs to the superior two nut system!
Post #821965 29th Mar 2020 10:04am
Devon-Rover
https://www.britpart.com/all-parts/da1118
Have used and abused my britpart 52mm deep socket according to my records I brought it on the 26th November 2010 Shocked (can you tell I'm bored and back through the landy invoices) Laughing Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #821970 29th Mar 2020 10:10am
donmacn
Definitely this. The replacement rear axle on my car came with the newer set up of spacer and the nut torqued up to 'daftNm'.
Having studied and digested various threads on the topic, I decided to ditch the spacer and go old-style when doing some other rear axle stuff recently. I'm familiar with this from the umpty-um times I've done trailer bearings, and it's so much easier to manage.
I'm lucky though in that I have a good impact driver, which took the 250Nm hub nut off without any drama. Luck, or planning ahead..... maybe.... can't remember.
As with benniferJ I have the impact socket and the tube spanner. I know which I'd pick up first - I didn't have any issues getting the socket to fit onto the inner hub nut. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #821983 29th Mar 2020 10:52am
