Home > Puma (Tdci) > 2013 Defender PUMA 2.2
Page 2 of 3 <123>
JimG
Not yet.
Post #818243 5th Mar 2020 9:11am
JimG
So the garage stated that when they pressurise they fuel system the engine starts and runs fine. When the ignition is switched off she fails to restart!
Post #818339 5th Mar 2020 7:33pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Sounds like air is getting into the fuel system.
Time for a new fuel filter.
Post #818343 5th Mar 2020 7:52pm
JimG
Fuel filter, housing and pipes replaced.
Post #818373 5th Mar 2020 9:23pm
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
fuel pump?
Post #818404 5th Mar 2020 10:48pm
JimG
Fuel pump being investigated this morning.
Post #818463 6th Mar 2020 11:22am
LR90XS2011
fuel tank breather pipe blocked? DEFENDER 90 TDCI XS,
Post #818556 6th Mar 2020 9:31pm
JimG
She runs fine once started with a bit of quick start spray. She also cranks ok and will continue to turn over until the battery dies. She just won’t start. I would imagine fuel pressure must also be fine for her to run after a bit of quick start spray.
Post #818793 8th Mar 2020 3:46pm
G4UJS
are the heaters/glow plugs working ok?
Post #818806 8th Mar 2020 6:08pm
G4UJS
does it start ok once its warmed up?
Post #818820 8th Mar 2020 7:05pm
JimG
Don’t know, but my gut feeling is that she is immobilised! I think it’s electrical possibly ECU/Alarm!
Post #818948 9th Mar 2020 9:11pm
Marks Landy
Key fob battery flat?
Maybe try spare keys.
Post #818961 9th Mar 2020 10:41pm
G4UJS
Cant see how it is the immobiliser as it starts with Quick Start....... hope you get it sorted soon, ?I would be going mad having just bought the vehicle , have you contacted the person who sold it to you?
Good luck
Rob
Post #819015 10th Mar 2020 12:45pm
JimG
Yep it’s being done under warranty! Moved on to a new garage now. They spent five hours on it yesterday but to no avail. They swapped out all the possible sensors but nothing. They now suspect it may be a stretched timing chain leading to a timing issue. The ECU is being swapped out on Friday. Can’t believe it’s that difficult! The fault is present all the to,e and it’s not even subtle! I heard these timing chains can cause starting problems. Has anyone any info on this? Cheers
Post #819124 11th Mar 2020 2:16pm
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
I'd avoid use of easy start or quick start at all cost. If they're still using it as part of diagnosis make sure they stop - absolutely horrendous stuff when used on a modern engine.
Immobilisers on puma's on Defender will stop the engine even if it's already running. You might get it to cough and sound like it's going to catch occasionally when you crank but certainly wouldn't get it to run normally at any point.
Things that can stop a Puma running...
Lack of clean crank signal
Lack of clean cam signal
Cam/crank sychronisation within ECU
Adequate fuel pressure (air lock should show up as inadequate rail pressure)
Correct injector voltages/traces
Everything else is tertiary. All the above should be easily readable/measurable using the right tools. Looking at this from a development engineering point of view, cam/crank sync and fuel pressure are the two main go to's and a LR dealer should be able to view them using dealership tools. If they asses which of the above isn't present, they should be able to be more methodical in their approach trying to find an "intelligence" based ECU problem or a physical failure rather than the dartboard diagnostics "change all the sensors".
All the above is irrelevant if it's the original OEM warranty, sit back, enjoy your courtesy car and let them fix their own problem Very Happy
Post #819154 11th Mar 2020 6:30pm
Page 2 of 3 <123>
