Home > In Car Electronics > Headlights stopped working |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 |
Should probably add that the headlights i have are h4 ones with led half crescent drls
20th Jan 2020 10:38am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Check the stalk that switches them on - prone to melt inside as the power for the lights goes through the switch.
20th Jan 2020 10:47am |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 685 |
Have you lost main and dipped beam?
I recently lost just dip, which turned out to be the pink relay , top right in under dash fuse box.( something to do with now obsolete dim dip feature) |
20th Jan 2020 12:31pm |
Only lost dipped beam so will have a look at the relay, im guessing thats not repairable and gotta get a new one?
20th Jan 2020 3:14pm |
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 |
My dipped beams often don't come on.....push stalk to full and back to dip and they come on..... have never gone out whilst driving....
its a Land Rover thing LOL regards Rob |
20th Jan 2020 3:33pm |
G4UJS
Turns out its exactly same problem you have hahaha I guess its just something I'll have to live with, never had that problem before though |
20th Jan 2020 5:34pm |
Adammacky
Tell me what you do to fix it LOL |
20th Jan 2020 5:45pm |
If i ever find a solution then you will be first to find out!
20th Jan 2020 5:57pm |
I would still check the relay, mine had one contact pin that had gone green.
When I pu the headlights on dipped wouldn’t illuminate however if I touched the relay they would come on. Everything would be fine again until the landrover was stopped for several hours, then it would play up again. |
20th Jan 2020 5:58pm |
gcc130 cheers will still check relay later
20th Jan 2020 6:01pm |
