Home > In Car Electronics > Headlights stopped working
Adammacky
Morning all, this morning in minus 2 weather i scraped the ice off the screen and drove to work as normal, on the way to work got flashed a few times and thought nothing of it, got to work to realise my headlights weren't on and only drls working, pretty sure they came on this morning when i left im sure i would have noticed while defrosting the windscreen otherwise, anyway before i finish work and diagnose the problem myself, has anyone else had the same issue? I cant imagine both bulbs have blown at the same time? Thought i may aswell get opinions on here before i get chance to do anything after finishing work at 5pm, what is the most probable cause? Thanks in advance Thumbs Up
Post #811123 20th Jan 2020 10:29am
Adammacky
Should probably add that the headlights i have are h4 ones with led half crescent drls
Post #811126 20th Jan 2020 10:38am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Check the stalk that switches them on - prone to melt inside as the power for the lights goes through the switch.
Post #811130 20th Jan 2020 10:47am
gcc130
Have you lost main and dipped beam?
I recently lost just dip, which turned out to be the pink relay , top right in under dash fuse box.( something to do with now obsolete dim dip feature)
Post #811145 20th Jan 2020 12:31pm
Adammacky
Only lost dipped beam so will have a look at the relay, im guessing thats not repairable and gotta get a new one?
Post #811168 20th Jan 2020 3:14pm
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
My dipped beams often don't come on.....push stalk to full and back to dip and they come on..... have never gone out whilst driving....
its a Land Rover thing LOL
regards
Rob
Post #811170 20th Jan 2020 3:33pm
Adammacky
G4UJS
Turns out its exactly same problem you have hahaha Rolling with laughter
I guess its just something I'll have to live with, never had that problem before though Confused
Post #811179 20th Jan 2020 5:34pm
G4UJS
Adammacky
Tell me what you do to fix it LOL
Post #811180 20th Jan 2020 5:45pm
Adammacky
If i ever find a solution then you will be first to find out! Thumbs Up
Post #811182 20th Jan 2020 5:57pm
gcc130
I would still check the relay, mine had one contact pin that had gone green.
When I pu the headlights on dipped wouldn’t illuminate however if I touched the relay they would come on.
Everything would be fine again until the landrover was stopped for several hours, then it would play up again.
Post #811183 20th Jan 2020 5:58pm
Adammacky
gcc130 cheers will still check relay later Thumbs Up
Post #811184 20th Jan 2020 6:01pm
