![]() | Home > In Car Electronics > JVC KW-M7 loosing DAB stations |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
You need both a switched live and permanent live for standby.
Are you losing all settings or just noticing DAB stations? Best way is to check that colours match to the rear, it could be that perm 12v and switched need swapping but you would need to check this. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751
Just noticed the DAB ones. I’ll check this week.
Good luck.
If your Defender is 2007 - 2012. The LR loom will be DIN ISO harmonised. (Standardised.) colours. The wiring diagrams for this is readily available online on a goodly photo search or similar search. If it's not wiring colours, there could be an issue with interpherence or picking up signal etc. I think you are right to check wiring colours first. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
