Home > In Car Electronics > JVC KW-M7 loosing DAB stations
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I’ve got the double din JVC. It’s great but I keep loosing the saved DAB stations. Am I right this is because it’s using a switched rather than perm feed?
Post #811032 19th Jan 2020 7:45pm
You need both a switched live and permanent live for standby.
Are you losing all settings or just noticing DAB stations?
Best way is to check that colours match to the rear, it could be that perm 12v and switched need swapping but you would need to check this. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #811047 19th Jan 2020 8:33pm
boxoftricks
Just noticed the DAB ones. I’ll check this week.
Post #811081 19th Jan 2020 10:44pm
Good luck. Thumbs Up
If your Defender is 2007 - 2012. The LR loom will be DIN ISO harmonised. (Standardised.) colours.
The wiring diagrams for this is readily available online on a goodly photo search or similar search.
If it's not wiring colours, there could be an issue with interpherence or picking up signal etc.
I think you are right to check wiring colours first. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #811088 19th Jan 2020 11:07pm
