Home > In Car Electronics > Light Bar Fuse Melting
Page 2 of 2 <12
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Always assume the figures for wattage and current draw are garbage. Only very few manufacturers (Rigid, Laser etc) quote somewhat realistic figures rather than theoretical ones. I tend to use one of these for unknown circuit draws.LINK HERE although cheaper ones are available.
24A would seem realistic for a 50" Bar. I tend to use (depending on cable run) 4.5mm2 (42a) by default for lightbar wiring as it covers every base I've come across so far and I usually fuse at 25ish amps.
As you have discovered, the wiring is too thin for the bar, but the fuse is blowing due to the high current, not because the wiring can't handle it, the two are mutually exclusive. Also when sizing cable we need to take into account distance to account for voltage drop.
A really helpful guide has been written by 12 volt planet and is available here and is well worth a read:
https://www.12voltplanet.co.uk/cable-sizing-selection.html
https://www.12voltplanet.co.uk/fuses-guide-uses.html
There is also a voltage drop calculator on there for those wanting to learn more and have a play around. CU040 - Cumbria 4x4 Response
Electrical Division @ K&S McKenzie, Carlisle
Post #810193 14th Jan 2020 11:29am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Thanks for all of that info, Duncans! Really useful!
Well, if nothing else, I’ve learnt a bit about electrickery. 2004 Td5 90
2012 TDCi 110
1958 Series 2 88
Instagram: @BaronDefenders
Post #810202 14th Jan 2020 1:13pm
Why not put a meter into the circuit and see what the actual current draw is, instead of going off 2nd hand info?
Out of interest why didn't you use the wiring kit the light is supposed to come with?
Post #810230 14th Jan 2020 7:04pm
90 Dreamer
Slightly OT but where are people routing wiring for the roof lights??
Post #810245 14th Jan 2020 7:53pm
topless_matt
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Through the roof behind passenger side bulkhead. Down into the seat box where the relay is housed. Hold my beer and watch this!
Post #810253 14th Jan 2020 8:30pm
90 Dreamer
As in physically drilling the roof or is there an alternative??
Post #810254 14th Jan 2020 8:31pm
DSC-off
If there is a raised air intake fitted, the wires can exit the engine bay under the bonnet gap. Then run up the side of the snorkle. Some intake kits have facility to neatly run wires or breather pipes inside the snorkle.
Mud stuff have some shrouded cable glands that look an acceptable solution if the cable has to go through the roof.
Post #810278 14th Jan 2020 10:32pm
donmacn
Mine are wired through the roof. If you do opt for that, rather than go to look at a 'car' accessory provider, I'd suggest having a good look at marine cable glands. I think the one I've got is "blue sea" but there will be others.
While a Defender roof will get wet, and deal routinely with 50-60mph 'winds', a marine fitting will be expected to deal with big lumps of water arriving with some force.
(Apologies to the OP - I hadn't appreciated that I was continuing the 'off topic' thing - though I hope it was useful!) Donald
(The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html)
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #810281 14th Jan 2020 10:53pm
Missed your link first time of reading - that's a nice bit of kit:
and rated to 80A according to the spec sheet.
I use a lowly TA123, only rated to 20A:
Post #810324 15th Jan 2020 10:02am
BaronDefenders
I shall see if I can get my hands on one of those!
And for the route question, my wiring goes between the windscreen frame and the door seal. 2004 Td5 90
2012 TDCi 110
1958 Series 2 88
Post #810334 15th Jan 2020 11:03am
hank
https://www.amazon.co.uk/Gunson-77068-Auto...B002WMYBS6 > 110 XS Double Cab
> Instagram @simonlanemind
Post #810335 15th Jan 2020 11:08am
You could look to improve that with something like this:
https://www.12voltplanet.co.uk/scanstrut-h...ables.html
But you could also say the way you have done it is the "official" way:
Post #810352 15th Jan 2020 1:27pm
DuncanS
Yep I have a scanstrut multiseal for the rear lightbar and rear roof accessories when I finally get round to fitting it. The front lightbar is going internally to the snorkel with some compression glands. CU040 - Cumbria 4x4 Response
Post #810458 15th Jan 2020 8:48pm
Page 2 of 2 <12
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
