Home > Maintenance & Modifications > Steering drop arm
geostrategist
United Kingdom 2008 Defender 110 Puma 2.4 CSW Tonga Green
Steering drop arm
I need to replace the steering drop arm. There is an option one for of a 6 bolt or 3-4 bolt PAS box.
Any suggestions of the correct one for a 2.4 TDCi '08 defender?
Post #809394 8th Jan 2020 8:09pm
Oldowner
4 bolt box
Post #809401 8th Jan 2020 8:39pm
geostrategist
Thumbs Up
Thanks
Post #809402 8th Jan 2020 8:40pm
grafty99
If replacing I would consider a disco drop arm conversion. The track rod end is much easier to replace going forward Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #809409 8th Jan 2020 8:55pm
Roy5695
What Grafty said!!
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #809413 8th Jan 2020 9:17pm
sako243
I wouldn't consider it, I'd just go ahead and replace it with Gwyn's kit.
The amount of play taken out of the system when I did it was incredible. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #809436 8th Jan 2020 10:41pm
geostrategist
Gwyn being.......?
Post #809460 8th Jan 2020 11:28pm
grafty99
Gwyn Lewis' company makes all sorts of uprated parts for landrovers. They do a full steering upgrade kit including the discovery drop arm and heavy duty drag link, track bar and track rods ends Thumbs Up
Just search Gwyn Lewis sumobars Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #809465 8th Jan 2020 11:38pm
Mo Murphy
Why do you need to replace the drop arm ?
50 Shades of Pennine Grey
Post #809470 8th Jan 2020 11:57pm
geostrategist
The ball joint needs replacing. It seems it’s easier to replace the whole drop arm rather then try to assemble the joint in place. It’s not too expensive either.
Post #809506 9th Jan 2020 8:57am
grafty99
That's exactly why the disco drop arm is a good upgrade. Just a simple track rod to replace. Turns it into an easy job Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #809516 9th Jan 2020 10:11am
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
the ball joint can be replaced in situ with a repair kit, i changed mine on saturday and fitted a grease nipple the whole job takes about two hours. nobody is perfect but being Scottish is a start
Post #809518 9th Jan 2020 10:21am
Oldowner
With the correct installation tool as well as the more common removal tool it is as quick as changing a track rod end (ten minutes maximum) and you don’t mess up your steering geometry if you don’t get the track rod end at exactly the same length as it came out.
Post #809549 9th Jan 2020 1:52pm
sako243
The main benefit I saw is that the track rod setup has less unwanted range of movement in it compared to the Swan neck style which results in more responsive steering. Ed
Post #809573 9th Jan 2020 4:55pm
