![]() | Home > Maintenance & Modifications > Steering drop arm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 679 ![]() ![]() ![]() |
4 bolt box
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 ![]() ![]() ![]() |
![]() Thanks |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
If replacing I would consider a disco drop arm conversion. The track rod end is much easier to replace going forward
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
What Grafty said!!
![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1248 ![]() ![]() ![]() |
I wouldn't consider it, I'd just go ahead and replace it with Gwyn's kit.
The amount of play taken out of the system when I did it was incredible. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Gwyn being.......?
Gwyn Lewis' company makes all sorts of uprated parts for landrovers. They do a full steering upgrade kit including the discovery drop arm and heavy duty drag link, track bar and track rods ends
![]() Just search Gwyn Lewis sumobars ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2382 ![]() ![]() ![]() |
Why do you need to replace the drop arm ?
The ball joint needs replacing. It seems it’s easier to replace the whole drop arm rather then try to assemble the joint in place. It’s not too expensive either.
That's exactly why the disco drop arm is a good upgrade. Just a simple track rod to replace. Turns it into an easy job
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 180 ![]() ![]() ![]() |
the ball joint can be replaced in situ with a repair kit, i changed mine on saturday and fitted a grease nipple the whole job takes about two hours. nobody is perfect but being Scottish is a start
With the correct installation tool as well as the more common removal tool it is as quick as changing a track rod end (ten minutes maximum) and you don’t mess up your steering geometry if you don’t get the track rod end at exactly the same length as it came out.
The main benefit I saw is that the track rod setup has less unwanted range of movement in it compared to the Swan neck style which results in more responsive steering. Ed
