Home > Technical > What happened? (shuddering)
Rednaxela
Hi,
Stock 300Tdi 90
Less than a couple of miles from cold into a journey today, I was on a quiet side road pulling up to a junction, so doing less than 20mph and reducing speed. Suddenly there was a bit of rough shuddering and a struggle for forward momentum.
The shuddering sound/feeling was coming from, generally, under the seatbox or a bit forward of that.
At the same time the steering and steering wheel wanted to pull to the left and it seemed slightly reluctant to be easily turned the other way. I decided to head home, and turned around and set off, which again there was a bit of shuddering but then after getting up to speed, everything was fine, as if nothing at all had happened.
Sounds unlikely but I'm hoping it was some gravel caught in a propshaft yoke, causing this power loss and jamming it hence sending the vehicle sharply to one direction.
I should add that every time I start it and reverse after the handbrake being on for a while there is a bit of a clunk, even when I release the handbrake and push the vehicle by hand (I was doing this recently to push it onto the flat before jacking it to do a task).
The A frame ball joint has been replaced, yet I read somewhere that with some kits the washer they come with isn't thick enough resulting in the nut not being tight enough, however mine was lemforder so I'm assuming I'm fine in this regard.
What do you think? Thanks for reading.
Post #808886 5th Jan 2020 7:35pm
ickle
Stone in the calliper / disc?
Post #808889 5th Jan 2020 7:55pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Propshaft U.J? Just because you're offended doesn't mean you're right.
Post #808896 5th Jan 2020 8:00pm
Rednaxela
At the time it seemed like a serious problem, I just don't think it would be from somthing caught in the brakes but I can have a careful look for any fresh scratching/scoring tomorrow.
Front propshaft is only 1000+ miles old, the rear isn't but seems sound.
When cruising along at speed everything sounds good.
Post #808901 5th Jan 2020 8:19pm
Sounds a big like a failed UJ bearing at a guess from symptoms. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #808902 5th Jan 2020 8:19pm
I fixed a neighbour’s that did this, I thought a bolt holding the handbrake onto the t/box had come out and was jamming in the drum...I was right that time! QRZ M8VPF
Post #808906 5th Jan 2020 8:22pm
doublecabjon
Greeni suggestion gets my vote, check the hand brake drum fixings. Perhaps try backing the adjuster right off and trying again- obviously being cautious as the hand brake will have little effect if needed.
Post #808913 5th Jan 2020 8:51pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
sticking handbrake or calliper.
my guess is handbrake binding Thumbs Up Have fun be happy
Post #808921 5th Jan 2020 9:06pm
Mo Murphy
Panhard rod bush failure ? Can set up a strong juddering vibration and difficulty steering.
50 Shades of Pennine Grey
Post #808926 5th Jan 2020 9:18pm
Rednaxela
Thanks for the suggestions this sounds like it.
Post #808937 5th Jan 2020 9:45pm
jst
Jamming cv? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #809081 6th Jan 2020 8:07pm
Rednaxela
I removed the handbrake drum - all was fine. Good opportunity to bench grease the rear propshaft anyway and I saw that the bolts holding the A frame upper link brackets to the chassis were a bit loose which should help explain some clunking.
I don't have any of the typical symptoms of a bad CV. The vehicle turns smoothly lock to lock with no clunking.
Post #809200 7th Jan 2020 2:39pm
