![]() | Home > Technical > What happened? (shuddering) |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864
Stone in the calliper / disc?
| shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 835
Propshaft U.J? Just because you're offended doesn't mean you're right.
| Rednaxela Member Since: 23 Sep 2019 Location: UK Posts: 47
At the time it seemed like a serious problem, I just don't think it would be from somthing caught in the brakes but I can have a careful look for any fresh scratching/scoring tomorrow.
Front propshaft is only 1000+ miles old, the rear isn't but seems sound. When cruising along at speed everything sounds good. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
Sounds a big like a failed UJ bearing at a guess from symptoms. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
I fixed a neighbour’s that did this, I thought a bolt holding the handbrake onto the t/box had come out and was jamming in the drum...I was right that time! QRZ M8VPF
| doublecabjon Member Since: 28 Sep 2014 Location: Dorset Posts: 31
Greeni suggestion gets my vote, check the hand brake drum fixings. Perhaps try backing the adjuster right off and trying again- obviously being cautious as the hand brake will have little effect if needed.
| Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 830
sticking handbrake or calliper.
my guess is handbrake binding |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2417
Panhard rod bush failure ? Can set up a strong juddering vibration and difficulty steering.
Thanks for the suggestions this sounds like it.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8488
Jamming cv? Cheers
I removed the handbrake drum - all was fine. Good opportunity to bench grease the rear propshaft anyway and I saw that the bolts holding the A frame upper link brackets to the chassis were a bit loose which should help explain some clunking.
I don't have any of the typical symptoms of a bad CV. The vehicle turns smoothly lock to lock with no clunking. |
| All times are GMT |
