Home > Puma (Tdci) > HELP FAULTY LIGHTS AGAIN !!!!!!!!
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
i kept loosing headlamp and highbeam and on advice changed mainswitch been ok for about a week and then lost the main beam pressed fusebox cover and they came on again then disappeared. took fusebox cover off and found out that if i pushed top right relays the main beam would come on intermittently any ideas ?????
Post #808078 30th Dec 2019 6:22pm
Either a duff relay or a poor connection on the relay holder would seem the obvious things to check. Darren
Post #808097 30th Dec 2019 7:58pm
gcc130
I’ve just had a similar problem with dipped beam.
I replaced the pink relay(top right) and has been fine since. I believe the relay has something to do with now obsolete dim/dip headlight legislation
Genuine relay was about £50 and we couldn’t find an aftermarket alternative.
Post #808099 30th Dec 2019 8:04pm
bunnyman
Thank you both for your help will try the pink relay
Post #808100 30th Dec 2019 8:13pm
bunnyman
Turned out to be headlamp relay burning out
Post #808376 1st Jan 2020 4:34pm
