![]() | Home > Puma (Tdci) > HELP FAULTY LIGHTS AGAIN !!!!!!!! |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Either a duff relay or a poor connection on the relay holder would seem the obvious things to check. Darren
| gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 790 |
I’ve just had a similar problem with dipped beam.
I replaced the pink relay(top right) and has been fine since. I believe the relay has something to do with now obsolete dim/dip headlight legislation Genuine relay was about £50 and we couldn’t find an aftermarket alternative. |
| bunnyman Member Since: 29 May 2013 Location: herts Posts: 126
Thank you both for your help will try the pink relay
Turned out to be headlamp relay burning out
| All times are GMT |
