Home > Maintenance & Modifications > Passenger heated seat not working
Bluest
As per the title, drivers side is fine and fuse is ok. The tell tale LED on the switch isn't illuminating either. Any ideas where to start looking? 2007 110 TDCi Station Wagon XS
Post #807165 21st Dec 2019 4:59pm
Check grounding continuity and if indeed there is a ground path present.
If there isn't, add a temporary ground path and if everything is correct you can go from there.
You can also check continuity on the live side as well, but make sure power is pruned off and isolated first
Are all plugs on the rear of the switch and unde seats clean, dry and fitted securely?
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #807182 21st Dec 2019 7:48pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Maybe swap the switches over?
Post #807186 21st Dec 2019 8:43pm
Martin
Site Admin
If the tell tale isn’t working it’s a switch issue or the power supply to the switch.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #807188 21st Dec 2019 9:30pm
Bluest
Thanks all. Based on that, the first port of call is swap the switches round. I should add, it failed intermittently for a while before going permanently u/s. 2007 110 TDCi Station Wagon XS
Post #807197 21st Dec 2019 11:51pm
Martin
Site Admin
Sounds like the switch then, hopefully is as they’re cheapest of the switches Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #807218 22nd Dec 2019 11:36am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
When my drivers side wasn't working I swapped the seat bases first to see if that was the problem...turned out that that was where the issue was. This is a very simple way of establishing were the issue might be!
Post #807265 22nd Dec 2019 9:06pm
