Home > My Defender > Defender 90
Page 18 of 22 <123 ... 171819 202122>
hank
Just had a really good trawl through this thread. Some really nice bits on this one!
Shame the pics at the beginning seem to be broken. > 110 XS Double Cab
Post #805744 11th Dec 2019 7:16am
Likeomg
Co1 wrote:
How do they feel?
Really nice, id say they are more controlled then before, dont know if its dampers / springs but the overall package is a lot more controlled as in it tracks the ground much better rather than packing up quick.
Say if you hit a set of large pot holes previous setup would feel a bit out of control, this just breezes over them... rolls slightly more but I can play with the low speed on the shocks to sort that.
The image hosting website I used to use doesn't exist... and all my pics went with it; sorry.... they are probably on a old laptop but id have to go looking.
Post #805780 11th Dec 2019 11:09am
Likeomg
Likeomg wrote:
Well here it is on the new springs... sits lower at the rear...
preferred the level'd look, quoted pic is old springs... these are new.
down 4cm by the stern....
Post #805833 11th Dec 2019 7:06pm
Sulisuli
Wow that is lowered on the stern Shocked I prefer the even look Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #805837 11th Dec 2019 7:33pm
Likeomg
Me too...
Post #805839 11th Dec 2019 8:01pm
Sulisuli
Can you “adjust” them as they have the separate reservoirs to raise the stern? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #805841 11th Dec 2019 8:08pm
Likeomg
No, ride height only by the springs... low speed compression (from my mtb experience) is slow movement like rolling in corners, high speed which is set is fast movement like hitting a pot hole...
Post #805847 11th Dec 2019 8:37pm
Zed
Those rear springs look too low to me. Unless you are going for the lowered look and the fronts are too high?
Are you sure they were a matching set of 4? WARNING.
Post #805850 11th Dec 2019 8:49pm
Likeomg
Part numbers check out... I do feel the rear is too low also... will get on the ramp tomorrow for a poke about.
got tracking at 10am so hopefully they can take some pics running out of time to get on my ramp.
Post #805876 12th Dec 2019 12:13am
hank
Stuff a winch on the front to bring the front down to match Razz > 110 XS Double Cab
Post #805882 12th Dec 2019 6:06am
Likeomg
If anything sitting a little higher is better for me, you see more of the shocks/ adrenaline 4x4 turrets... looks super cool.
Post #806707 18th Dec 2019 1:13am
Likeomg
So whilst drifting around for the last 6 months i've accumulated a few things to fit / do when im back
starting to forget what ive ordered and bought so thought id keep track here
fit new air con condensor
nugget stuff air intake
genuine XS side steps - Old ones dont fit with bowler sills
Genuine XS sides (convert to a CSW without seats)
YRM seals tub to sides
YRM stainless washers for rear shocks
Billet washer outlet
new windscreen wipers
stainless brake hose kit
Relocate my 2 amps 9hertz HDP4 and HDP1)
Fox roost shields
off to alive to have the ride height sorted, i had thought about just fitting these but with the paint rubbing off after 100 miles i'd prefer different rear springs https://gwynlewis4x4.co.uk/product/1-12-inch-rear-spring-spacers/
Post #832514 22nd May 2020 4:54am
Co1
That’s quite a list! Do you even know when you’ll be back?
Where did you get the fox roost shields? I’ve had no luck at all finding them in the UK?
Post #832516 22nd May 2020 6:01am
Likeomg
Yeah, eager to get on with it.
For now, we are sending the non essential crew home... for the rest of us nothing yet... weird having 280 people in a ship designed for 8880.
We’ve been hit by the tail end of Andrew for the last few days, got some good pics..
The roost shields try ‘prolinx’ they are the fox importers, they helped me out with some washers that are needed to try adapt them to fit... I haven’t looked into it yet I’ll make it work somehow
Post #832518 22nd May 2020 6:44am
Likeomg
Well I got back on dry land around 10 days ago now,
went out to alive to sort the rear springs anyhow few limp modes on the way down, turns out the turbo actuator was seized so hybrid off and for a rebuild... took it apart and one of the vanes was stuck managed to get it free but still didn't trust it
anyway gave me some time to sort the roost shields and put the rear windows in...
some modification needed to get these to work,
and windows... I prefer the look and being able to see in the blind spot, finishes with Masai 4x4 alcantara in Stornaway grey
Post #846095 26th Jul 2020 9:38am
