Home > Maintenance & Modifications > Ball Bearing Security
Page 2 of 2 <12
williamthedog
I use metal putty pushed into mine. Thumbs Up
Post #803067 21st Nov 2019 12:16pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Another point of weakness is the actual door stays themselves. They are very easy to disconnect.
I am just about to fit security bolts to the front and rear doors instead of the simple clevis pin on the front door and standard bolt on the rear. For the middle doors I am going to fit security caps on the door stay nuts.
Hopefully will get this done this weekend and will report back if it all fits as planned.
Post #803068 21st Nov 2019 1:17pm
Mo Murphy
I'm lucky enough to not have the attractive kind of door 😇
50 Shades of Pennine Grey
Post #803077 21st Nov 2019 2:20pm
Scotm
Maybe some stick on rust patches is the answer?!
Post #803078 21st Nov 2019 2:42pm
Mo Murphy
No, stick on square corners and window winders 😂
Post #803079 21st Nov 2019 3:10pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
LandRoverAnorak wrote:
They're easy enough to insert and difficult, although not impossible to lever out again, which is of course the whole point.
As an aside, I recently came across these on eBay, which appear to be a slightly more elegant solution. I suspect removal would require some very careful drilling:
https://i.ebayimg.com/images/g/BjQAAOSwm~daaF5i/s-l1600.jpg
I bought those a while back and found that they're not much use on the Nakatanenga stainless bolts because they don't stay put in the Torx hole. They can be bonded in place but even then they protrude and can easily be extracted using a screwdriver/chisel + hammer. The vendor indicated that he'd recently experienced the same on his son's vehicle and offered a complete refund.
Post #803085 21st Nov 2019 4:39pm
TheShrink
If using silicone, is there any specific silicone that people would recommend?
Thanks
Post #803148 22nd Nov 2019 10:33am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Mo
Rolling with laughter Rolling with laughter Rolling with laughter ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #803150 22nd Nov 2019 10:40am
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
have got these inserts in each of the top hinges on the A post, and they have been hammered well in . Has anybody succeeded in removing and how did you go about it. I want to replace all the bolts with SS and am tempted to just leave these in place as the insert shows no rust and as the vehicle is Orkney Grey they blend in quite well.
any thoughts?
Post #838899 22nd Jun 2020 3:06pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
^^^ Anyone asking how to defeat security measures will be unlikely to get much information provided. Whilst it might be frustrating, it is also very reassuring when you think about it.
Post #838919 22nd Jun 2020 4:07pm
lakelander
thanks for reply. Yes i understand - but these inserts are a deterrent to make an opportunist think twice as whatever method you use it will be time consuming. They seem to be a simple, cheaper and unobtrusive way to help you keep ypur doors. Have decided to leave them as they are Smile
Post #838922 22nd Jun 2020 4:19pm
Page 2 of 2 <12
