![]() | Home > In Car Electronics > Alpine Halo 9 |
tamar817 Member Since: 07 Nov 2019 Location: Durham Posts: 11 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge It will cover nearly all of the buttons and the heater controls. It depends how many buttons you have. The hazards are obstructed, this might be a problem. It doesn't seem like a problem day to day, but i am looking to move the hazard warning switch to the end, block the heater vents and move the screen up a bit. I didn't fully tighten the screws up so the screen can be tilted freely. It is a very nice unit and have no regrets about installing it, but if alpine made a halo 7 I would swap it out very quickly. |
Pioneer sph-evo62dab-uni
It is another option. If you don't install the back cover you can still get to the hazards. You can easily get to 4 of the buttons and the other 2 can still be used ok. Window and heater controls are still accessable. It is a little difficult to see as it has no angle adjustment and in a truckcab you can't put the seats back far enough to get a good angle. ![]() Click image to enlarge ![]() Click image to enlarge |
Wildrover66 Member Since: 25 Apr 2018 Location: Kildare Posts: 52 ![]() ![]() ![]() |
Hi Tamar 817
How is the Halo 9 functionality, interfaces etc Does it link well to apps as keen on using it with Google maps and spotify Do you have a camera fitted to it if so what is the picture clarity like Sorry for all the questions but keen on getting one of these for figment to a raptor dashboard |
I have only used it with Android Auto.
I normally use YouTube Music and that works great, but I have used Spotify and that seemed to work fine. I had a little bit bother with usb cables with some android phones, but this is the case with all android auto headunits. Google maps works great The unit has its own GPS receiver and an antenna that will need installing to get the best reception, but it will also use the GPS signal from the phone. I used it for a few weeks without the antenna installed and it worked fine. I have not connected the camera up yet, but the screen is very clear and the capacitive touchscreen is nicer to use than the resistive ones on the Pioneer units. |
Why do you need USB cables doesn't everything connect via bluetooth? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21005 ![]() ![]() |
USB provides power and superior SQ.
You’d soon find BT would run batteries down very rapidly. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
USB is required for Android Auto and Apple Carplay.
