Home > Maintenance & Modifications > Help me spend my money - Axles |
Not_Given Member Since: 25 Dec 2017 Location: UK Posts: 80 |
Brilliant! Thanks, blue.
Also found this pdf on here for others reading this thread https://www.defender2.net/gallery/albums/u...8v2-a1.pdf |
8th Nov 2019 11:40am |
Thank you, Harry. I had assumed Ashcroft replacement diffs come with Mag plugs. I will check.
8th Nov 2019 12:18pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Go direct to Bailey Morris. Newer version and cheaper If youre having the diffs built go to Nige at Xcess 4x4. Second to none in the UK. Instagram @defender_ventures Empire Tuning - Agent |
8th Nov 2019 12:39pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1186 |
Second Nige, a friend has had both of his diffs into Ashcrofts a total of 4 or 5 times now with various issues after having new centres installed with various bearing and pinion issues, this is a vehicle that does about 2-4k per year. Since going to Nige he hasn't had an issue. Ashcrofts build some fantastic stuff but I'd go to Nige for the actual build up. Bonus is that Ashcrofts will ship direct to him for nothing. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
8th Nov 2019 1:16pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
So are you planning to far afield or just everyday use ?
Will you carry spares ? The reason I ask is that by fitting HD everything you just move the weak link further down the drive train. Ultimately the transfer box becomes the weak link which is a lot harder to repair in the field than a broken half shaft or stripped drive flange. All the HD kit was developed for the hardcore winch challenge scene where powerful engines and 35'' tyres ate the standard items for breakfast. If you are getting them just because you can, then fair play enjoy, if you are equipping for a proper overland trip then think carefully about where your weak link is going to be and how easily will it be to repair. My own spec, is a standard 10 spline front diff, 24 spline rear diff with ARB locker, standard shafts all round (disco one piece on the rear) and a standard LT230 transfer box. Never broken a half shaft in 25 years of use but I do carry spare long half shafts just in case on foreign jaunts and laning. Not being critical of your choice just advising a little thought and caution depending, of course, on your intended use. HTH Mo The Land Rover 90 - Many are called, few are chosen. |
8th Nov 2019 7:06pm |
+1 on the above. Though I tend to snap short shafts!
Shafts are cheap and easy to replace (with the right wheels rears can be done in less than 10 mins) Fronts little more involved but I have done two front shafts/CVs in the field with limited spares. Click image to enlarge Even though ive now broken 4 front shafts/CVs I wont be going HD as itll just do damage elsewhere. However me and a mate did have a chat and thought if you did have HD everything make some weak flanges. I E remoce every other toother on a standard cheap flange. That way if something breaks its 10 mins and a £5 part not £2k on a box and youre stranded. That said each to their own. Instagram @defender_ventures Empire Tuning - Agent |
8th Nov 2019 9:00pm |
^^^^ Ruff arse !
9th Nov 2019 8:09am |
Some great food-for-thought there. I appreciate the time you‘ve all taken to respond. My philosophy is ‘Buy once, buy right.’ So, why a defender, you may ask? Infinitely repairable and upgradeable, but with a soul. And it makes me smile. I don’t intend to buy another vehicle. Ever.
The drivetrain upgrades are part of a long term plan that hopefully will culminate in a LS and auto box (which may end up living in Canada). The transfer box will get its love and attention then. The point about only being as strong as the weakest link is very valid, but I don’t do hard wheeling, just like to get out there. Hopefully I am not speaking too soon!. It’s only money! Thanks again, all |
9th Nov 2019 12:13pm |
Piggy501 Member Since: 27 Sep 2017 Location: Scotland Posts: 56 |
While Nige can build a super strong diff he also sells modifications that, while they might not add outright strength, do add to the longevity of your components, his diff pinion flange as an example, or magnetic plugs. Little things that wouldn't take much to add while getting a diff built up, but like you say, would be a bit of a pain to fit once the axles are back under the vehicle. |
9th Nov 2019 1:39pm |
Yup and ever improving. Both my diffs are Ash centers in a Pegged ultrabuild casing. Far from cheap but flawless. Instagram @defender_ventures
9th Nov 2019 3:43pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
The basic trouble with a Land Rover drivetrain is that you spend money strengthening one item only for the next part up or downstream to break.
If you want stronger axles, it might be worth your while considering these, ideally in conjunction with Dana (Salisbury) axles front and rear. http://lvboverland.co.uk/tibus-portals/4593873706 It is not a Defender, it is a One_Ten |
10th Nov 2019 5:12pm |
I’ll bet they’re not cheep!
Seen a G-wagon 6x6 with portals in the Middle East. Could practically walk underneath the thing. |
11th Nov 2019 2:30pm |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 |
I've run lockers with ashcroft shafts, drive flanges, and cv joints on 2 different 90's for the best part of 8 years. A mate has run the same set up for about 6+ years. Neither of us have had any issues with parts breaking either in the axles or gearbox/transfer box and they are used regularly.
11th Nov 2019 8:27pm |
