Home > Puma (Tdci) > Headlights
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
Headlights
HI all main beam has been turning itself off just leaving sidelights on and then turning back on for no apparent reason anybody any idea s
Thanks bunny
Post #800378 1st Nov 2019 7:57pm
dorsetsmith
see post below Arrow
Post #800384 1st Nov 2019 8:28pm
Sounds like the switch has failed. This usually takes the form of the plastic that holds the brass contacts melting and allowing them to move, hence the intermittent nature of the problem as it heats up and cools down. Darren
Post #800407 1st Nov 2019 10:27pm
bunnyman
Thank you both for your reply’s will try. New switch tomorrow
Post #800411 1st Nov 2019 10:32pm
Out of curiosity.
Do you have an upgrade headlight loom or not?
I’m guessing not in this case hence what LRA has mentioned above becomes an issue without an upgrade loom. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #800414 1st Nov 2019 10:39pm
bunnyman
No I haven’t a upgraded loom do I need one are they exspencive and could I fit one?
Post #800419 1st Nov 2019 10:56pm
grafty99
I had identical symptoms on my Td5 90. It was the pink headlight relay Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #800421 1st Nov 2019 11:17pm
dorsetsmith
i misread your post as LandRoverAnorak post the switch
have read this link re JLR head light switch up grade mod using relay slaved to the head light switch to handle the load
https://1drv.ms/b/s!AtZSoWFHDgnGkjJVf5vaREsU7XKN?e=dYfeID
Post #800422 1st Nov 2019 11:26pm
grafty99
Just re read your post bunnyman, when you say main beam, are you referring to main beam or dipped beam? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #800423 1st Nov 2019 11:52pm
bunnyman
Yes dipped beam but when I loose dipped beam I can still get high beam if I hold long stalk on flash
Post #800436 2nd Nov 2019 7:57am
grafty99
Ah OK. In which case it's likely to be the switch Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #800443 2nd Nov 2019 9:22am
