![]() | Home > Puma (Tdci) > Headlights |
see post below
![]() Last edited by dorsetsmith on 1st Nov 2019 11:37pm. Edited 1 time in total |
Sounds like the switch has failed. This usually takes the form of the plastic that holds the brass contacts melting and allowing them to move, hence the intermittent nature of the problem as it heats up and cools down. Darren
bunnyman Member Since: 29 May 2013 Location: herts Posts: 125 ![]() ![]() ![]() |
Thank you both for your reply’s will try. New switch tomorrow
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20974 ![]() ![]() |
Out of curiosity.
Do you have an upgrade headlight loom or not? I’m guessing not in this case hence what LRA has mentioned above becomes an issue without an upgrade loom. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
No I haven’t a upgraded loom do I need one are they exspencive and could I fit one?
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I had identical symptoms on my Td5 90. It was the pink headlight relay
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
i misread your post as LandRoverAnorak post the switch have read this link re JLR head light switch up grade mod using relay slaved to the head light switch to handle the load https://1drv.ms/b/s!AtZSoWFHDgnGkjJVf5vaREsU7XKN?e=dYfeID |
Just re read your post bunnyman, when you say main beam, are you referring to main beam or dipped beam? 2002 90 Td5 Station Wagon
Yes dipped beam but when I loose dipped beam I can still get high beam if I hold long stalk on flash
Ah OK. In which case it's likely to be the switch
