![]() | Home > Puma (Tdci) > Headlights |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
see post below
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Sounds like the switch has failed. This usually takes the form of the plastic that holds the brass contacts melting and allowing them to move, hence the intermittent nature of the problem as it heats up and cools down. Darren
| bunnyman Member Since: 29 May 2013 Location: herts Posts: 126
Thank you both for your reply’s will try. New switch tomorrow
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
Out of curiosity.
Do you have an upgrade headlight loom or not? I’m guessing not in this case hence what LRA has mentioned above becomes an issue without an upgrade loom. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
No I haven’t a upgraded loom do I need one are they exspencive and could I fit one?
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4804
I had identical symptoms on my Td5 90. It was the pink headlight relay
i misread your post as LandRoverAnorak post the switch have read this link re JLR head light switch up grade mod using relay slaved to the head light switch to handle the load https://1drv.ms/b/s!AtZSoWFHDgnGkjJVf5vaREsU7XKN?e=dYfeID |
Just re read your post bunnyman, when you say main beam, are you referring to main beam or dipped beam? 2002 90 Td5 Station Wagon
Yes dipped beam but when I loose dipped beam I can still get high beam if I hold long stalk on flash
Ah OK. In which case it's likely to be the switch
| All times are GMT |
