![]() | Home > Puma (Tdci) > Duff defender ? |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Someone from your neck of the woods will hopefully be along shortly to recommend a good independent near you. That’s where I’d start.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17903 ![]() ![]() ![]() |
Check that all the relays under the driver's seat are really tight in their sockets. There are two which must work reliably for the engine to crank and start, and a loose connection on these is a common problem.
JellyBean Member Since: 02 Mar 2015 Location: Suffolk Posts: 142 ![]() ![]() |
Nick - I use info@offroadrovers.co.uk. I’ve always found Paul there very helpful. Hope they can resolve the issue for you.
Nick90pickup Member Since: 21 Oct 2019 Location: Suffolk Posts: 16 ![]() ![]() |
Thanks everyone, I have wiggles and giggled all the wires I can under the seat but sadly that's not helped.
I shall try Paul and see if he might be able to help. Or if there are any other local suggestions If you have any other thoughts please let me know. |
Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91 ![]() ![]() |
Ignition barrel?
Do a search on here, LOTS of odd behaviour caused by these. |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
I'd second the ignition barrel. Replace with a genuine Land Rover one.....
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
What do you mean by this? The normal warning lights (glow/MIL) don't appear, or there are none at all, or nothing out of the ordinary? The issues sounds similar to johnnyd's problem which a new ignition switch and connecting it correctly resolved: https://www.defender2.net/forum/post767041.html#767041 If you can I would make up a temporary starter button/wire to try. Just a push button switch with a length of wire on each side. Or at a push - a length of wire cut into two pieces which you can touch to make the circuit ![]() I can give more info on where to fit it and the process for testing if you go down this route ![]() ![]() ![]() |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello Nick90pickup
If you rename your problem as an 'intermittent starting problem' then I too would check / replace the ignition barrel to at least eliminate this from the problem if not solve it if you're lucky...cheap part (which is probably the issue) and for a Puma (with a shelf below the steering column) can be a ![]() My story... https://www.defender2.net/forum/topic51335.html Good Luck ![]() https://www.defender2.net/forum/topic83242.html |
Dexterdog Member Since: 23 Jun 2018 Location: gloucestershire Posts: 108 ![]() |
Hi Nick, I have the same truck as you and had what sounds like a very similar thing. It would turn over for a bit and then just stop turning over. Try again and the length of time it turned over before it stopped trying varied, sometimes a split second, sometimes 5 or 6 seconds or anything in between.
Leave it alone for 5 mins come back and it might do it again or it might fire up straight away and not give any problems until a few weeks later when it repeated the problem. Someone on here suggested its the relay under the drivers seat. What they told me is you want to have to really pull on it for it to come out. If it just slides out with little pressure, give the spade connectors on the relay a sideways twist (careful how far) and slot in again. Repeat until you have to really tug the relay to get it out. It worked for me, it was obviously a relay connection issue and I have never had the problem since. Good luck |
That sounds very intresting. I assume this is easy to do? |
Thanks, I shall have a look and see if I can get one. As you say it will rule it out if nothing else.
We have managed to tow it on to a trailer so at least she moves now ![]()
Thanks I have given them all a good wiggle and push. But I shall see if I can work out the tips above and see if it's the ignition barrel. |
Thanks for the idea. Would you get the entire thing, as in new keys ect,? I have had a google on the interwebs about 100 pounds and comes with new keys. I assume this will not effect anything else on the truck ? Like ecu or another computer ? I assume this would show as a fault code if the thing plugged in at a service centre? Thanks Nick |
