Home > Tdi > Car starts but wont run suspect ignition switch
Wildrover66
Ireland 1997 Defender 110 300 Tdi SW Orkney Grey
Hi
1997 300 Tdi
Just stopped for fuel and the car wont start or run. All good before this.
No dash lights at position 2 of the key
At position 3 car starts and dash lights work if you hold it in this position it runs but starter motor engaged. return to position 2 and she stops.
Is the first port of call a new ignition switch or are there other possibilities ,relays ,fuses,earth straps etc
As said she runs in position 3 just nothing in position 2 , also to add main headlights wont work either in position 2 all other lights working.
And yes it was filled with Diesel not a fuel issue Very Happy
Thanks in advance
Post #797342 8th Oct 2019 10:07pm
jst
Check wiring on back of ign barrel and feeds to it for pos II Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #797359 9th Oct 2019 7:41am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Mine had similar issues once, removed the cowling and found the back of the ignition switch had just about fallen out, new ignition switch fitted and was all good. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #797388 9th Oct 2019 12:07pm
Wildrover66
A quick update
checked power at all switch positions and all measures normal 12+ v
Still no dash lights in position 2
Last thing in the circuit to check is a header joint K109 which I cant find
Anyone know where to look
All fuses good
I have a new switch ordered which I will fit when it arrives even though all appears normal there
Thanks for your input
Post #797602 10th Oct 2019 6:04pm
dorsetsmith
header joint K109 ( C285 ) up behind the dash
white wire
Post #797615 10th Oct 2019 6:48pm
Wildrover66
Cheers I will look for it in the morning
Post #797626 10th Oct 2019 7:42pm
Wildrover66
C285-17 if I read this correctly is directly connected to switch position 2. I have power at switch but no dash lights
Post #797654 10th Oct 2019 10:26pm
dorsetsmith
that`s right check at the header for 12 volts
also provides 12 v power to the engine fuel stop sol
Post #797659 10th Oct 2019 10:55pm
Wildrover66
Fixed new switch arrived so decided to try it prior to chasing voltages
Old one internals pictured no damage but some wear
Top right on left position 2 but a couple were loose to touch
Thanks for your replies
Post #797726 11th Oct 2019 2:53pm
dorsetsmith
good Thumbs Up
Post #797729 11th Oct 2019 3:42pm
