Home > Tdi > Car starts but wont run suspect ignition switch |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7664 |
Check wiring on back of ign barrel and feeds to it for pos II Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
9th Oct 2019 6:41am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Mine had similar issues once, removed the cowling and found the back of the ignition switch had just about fallen out, new ignition switch fitted and was all good. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
9th Oct 2019 11:07am |
Wildrover66 Member Since: 25 Apr 2018 Location: Kildare Posts: 49 |
A quick update
checked power at all switch positions and all measures normal 12+ v Still no dash lights in position 2 Last thing in the circuit to check is a header joint K109 which I cant find Anyone know where to look All fuses good I have a new switch ordered which I will fit when it arrives even though all appears normal there Thanks for your input |
10th Oct 2019 5:04pm |
header joint K109 ( C285 ) up behind the dash
white wire Click image to enlarge Last edited by dorsetsmith on 10th Oct 2019 9:42pm. Edited 1 time in total |
10th Oct 2019 5:48pm |
Cheers I will look for it in the morning
10th Oct 2019 6:42pm |
Click image to enlarge C285-17 if I read this correctly is directly connected to switch position 2. I have power at switch but no dash lights |
10th Oct 2019 9:26pm |
that`s right check at the header for 12 volts
also provides 12 v power to the engine fuel stop sol |
10th Oct 2019 9:55pm |
Fixed new switch arrived so decided to try it prior to chasing voltages
Old one internals pictured no damage but some wear Top right on left position 2 but a couple were loose to touch Thanks for your replies Click image to enlarge |
11th Oct 2019 1:53pm |
good
11th Oct 2019 2:42pm |
