Home > Maintenance & Modifications > Changing the springs |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2555 |
Half the point of a Land Rover is that you can work on it yourself. And as pointed out above if you are replacing like for like there should be no insurance implication, how would they even know if I replaced the springs with new ones like for like?
Where does it stop? Am I qualified to replace brake pads, or change a wheel? I am sure the T&Cs will say that the vehicle has to be maintained correctly to manufacturers recommendations or some such guff, fair enough. But they can’t force you to pay through the nose at a stealers to do it. |
6th Oct 2019 10:49am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19602 |
I did my own springs and some other things
I do however know my limits for safety’s sake so personally I don’t touch brakes and steering components etc. There are members here that are in the trade and or engineers who are fully capable. However, that can lead some to believe they have the capability to push their boundaries too to match. That’s all I’d say really, is know your limits. And don’t under any circumstances take on a job you are unsure if you can fulfil to completion. And never take any risks. Like when jacking always keep clear and have a form of safety device should a jack fail or similar event. And don’t use the screw pillar jack! Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
6th Oct 2019 1:11pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
Agree with you totally steve !If i had say done some diy work on my truck say change springs and put in some isolators and stronger front cones and i had a crash. If it was found i had not seated the springs properly and caused the crash i would not be happy but i would not complain if they refused my claim...
However if i had done everything correctly and had a crash and some eagle eyed inspector noticed that the isolators on my springs were not factory standard on my 90 and tried to wriggle out of the claim on that basis ..i would be a little peeved to say the least! |
6th Oct 2019 3:12pm |
The isolators do a good job. Been using them top and bottom all around on my 90 now for a few years. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
6th Oct 2019 5:59pm |
