![]() | Home > Maintenance & Modifications > Anyone have experience of bilstein and fox? |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2026 ![]() ![]() ![]() |
![]() ![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Just say they are the wrong colour ![]() ![]() Instagram - @r22oyp Roy |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Priceless
![]() ![]() ![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
unfortunately Emma knows how much I've spent recently
![]() But my lips are sealed, just make sure your tip is clean ![]() Instagram - @r22oyp Roy |
So Col1 have you ordered your foxes yet?
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
doncarloz Member Since: 29 Oct 2017 Location: Styria Posts: 60 ![]() ![]() ![]() |
Would you recommemd those fox shocks for Standard ride height defender that's driven offroad quite extensively aswell?
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Yes definitely👍 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Well I can now give an opinion on both. I’ve got standard height comfort springs from alive and had them for both sets of dampers. The fox is defiantly a more comfortable ride at low speeds. Speed bumps and ruts in the road etc are much more bareable, but don’t be expecting a Range Rover! If you like to drive fast, then these are probably not the dampers for you and the B6’s would be more appropriate.
The Fox’s are much softer, and possibly a bit wallowy. I may well end up fitting the update d ARB over the standard, but will see. B6’s are stiffer but still more compliant than standard. Off road, first impression are the Fox’s give better traction over B6’s and definitely over standard. Is it worth twice the price? Depends on what you want from your landy I suppose. For me, a steady driver that never gets over 60mph and is never in a rush; definitely. If you like whipping down country roads and tight bends, stick with the B6’s. |
Good review Co1. 2015 HT XS 90
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Decent review Co1. Also mirrors what others have told me.
I'm happy they have worked out for you. WARNING. This post may contain sarcasm. |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 ![]() ![]() ![]() |
I have also had both B6s and the fox fitted with the Alive standard comfort springs but I also had the uprated Alive ARB fitted.
in both cases. I have found the high speed handling with the fox to be equally as good as the B6 but as stated the fox are more compliant over small bumps so the best of both worlds. In my opinion Installing the uprated ARB is one of the best mods you can make to improve on road handling and virtually eliminates the wallowing Co1 mentions. Even with standard springs and shocks the uprated ARB is a great mod for road use. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Is the uprated rear ARB also a good mod for the 110?
I take it it's the Eibach one on the Alive site? |
Thanks a lot MJN, I thought the spending had ceased for a while at least; it hasn’t even stopped for a week yet and now this!! ![]() |
