Home > Puma (Tdci) > MAF and MAP Sensor replacement.
Page 2 of 6 <123456>
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
I have a 2010 2.4 tdci would the MAF you have sourced be a replacement for mine?
NB nothing wrong with the sensor on mine other than the little locking tab seems to have sheared off so the plug wont click onto the sensor Neutral
Post #790496 4th Sep 2019 2:20pm
You can get a repair kit for that connector.
And yes, that is the correct sensors for the 2.4’s. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #790542 4th Sep 2019 6:21pm
lonewolf
Hi Steve, yes I got the new bare plug as the catch on the existing one (red) had broken. I replaced the red sliding catch only to realise that the catch (raised tab) on the MAF body where the red catch attaches to was not raised anymore and had either worn down or sheared off. So now my plug fits on but it can’t latch down. As the vehicle is now 10 years old it may be just as well to replace the MAF sensor anyway.
I hope my description is understandable?
Post #790547 4th Sep 2019 6:44pm
Yes, I know what you mean.
As you've figured no doubt, that locking tab I should be there for a reason and is important to stop the plug coming off.
So if the MAF side is worn and not allowing it to latch, it could indeed do with replacing.
Mine was of similar age too, chances are it will be beneficial anyway.
Since I've done both of mine, it's been running great. Better than quite a long time.
That is despite still keeping them clean. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #790568 4th Sep 2019 8:20pm
lonewolf
The new MAF has been ordered Steve, thank you for the link in your original post Thumbs Up
NB I did manage to get the red tab out of the new plug and have put it in the original. That saves either pulling the wires out and fitting to the new plug or cutting wires and attaching a wired plug....much easier.
Post #790571 4th Sep 2019 8:31pm
Thumbs Up
Feel free to report back after, I'd recommend doing the MAP too whilst at it.
I found this to be the biggest improvement, but is a little bit more involved but nothing much. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #790598 5th Sep 2019 12:15am
ericvv
Catherinestreetmotors, the suggested MAF sensor supplier, does not want to ship outside of UK. Looked for another possible supplier for the MAF sensor, and found the below one (=Transitparts). Ordered, and correctly they also priced it net of VAT for shipment to Switzerland. Just hope it is the genuine Ford part. Will see. At least the customer comments are all positive.
https://www.amazon.co.uk/SENSOR-TRANSIT-MO...=8-1-fkmr0
The suggested MAP sensor supplier had no problem with shipment to me, and at very reasonable cost I must say.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #790600 5th Sep 2019 2:47am
Glad you found an alternative Eric.
Hopefully that will work for you.
The Ford Genuine parts would be readily available I should think but not in particular online.
Probably to sell via dealers for fitting at double price. You’d be surprised how few people know what these sensors are, what they do and how easy to change they are.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #790644 5th Sep 2019 10:27am
lonewolf
Eric, re genuine or not......in the questions and answers, following the link you posted someone has asked and they said no, not genuine Ford.
I’m sure it will work fine though as the reviews look good.
Post #790664 5th Sep 2019 12:19pm
ericvv
Post #790670 5th Sep 2019 12:42pm
Chuchi_EL Drac
Spain
Hello,
Thanks for so interesting post.
This is a photo of my MAP sensor on a Defender 2.4 2010.
You can see the Bosh reference is 0 261 230 255. Will be change by 0261230131?
Post #796539 3rd Oct 2019 1:08pm
Is correct for a 2.4.
Mine was 0261230132 as factory fit.
Bosch seem to have changed the P/N’s at times but 0261230131
Is the current up to date spec for the 2.4 Motor in a Defender or Transit.
Mine has been fitted some time now, and running as good as ever. Zero issues. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #796564 3rd Oct 2019 5:22pm
lonewolf
Hmmm.......mine has the same number as Chuchi-el drac as well ie 0 261 230 225, (2010 2.4) I wonder why others have different no’s ?
You can still get a genuine Bosch map sensor with that number too. Around £25.
Post #796810 5th Oct 2019 4:51pm
mobilesawmiller
Steve,
Just wanted to say thanks for the information and advice. Changed both on my 94,000 mile 07 Defender 90. Tick over is definitely smoother as is acceleration.
Cheers Mate.
Post #797520 10th Oct 2019 7:25am
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #797541 10th Oct 2019 10:52am
