Page 119 of 1391 <123 ... 118119120 ... 138913901391>
Zagato
Better just correct what I said about the Mobile Security Systems chest not fitting the right way up before I get complaints from the company as they will be looking Whistle (Apologies Clare!)
The chest does fit the correct way up but sticks out by 1.5" on a SW Puma because of the thicker window surrounds. I decided to fit it the correct way not on it's side and it is a quality bit of kit Thumbs Up
Post #78267 28th Jun 2011 9:00pm
WarPig
That looks good Zagato. Thumbs Up
Post #78278 28th Jun 2011 9:43pm
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
Finally fitted the noise suppressor for the CB. Not wanting to drill holes everywhere it'll still only be plugded in when I need it, but the alternator whine has gone and only a very slight amount of crackling now.
It's very much a compromised set up, but after taking another couple of mm off the bottom of the aerial, the SWR is a little lower and I managed to communicate 4.2 miles yesterday at 5lb with no interference. That's over 16x better than using the rubber duck inside the vehicle, although this was decent, in reception and transmission, but only for 1/2 a mile.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #78308 29th Jun 2011 6:43am
RED-DOT wrote:
The sump is £30 . Oil is £40 and filter a tenner.... did Dr Who fit it?
Oil £55.84
Filter £9.98
Sump plug washer £2.60
Labour for oil change £88.50 less 20% = £70.80 Shocked
Sump pan £30.90
Gasket £12.17
Labour for sump pan change £106.20 less 20% = £84.96 Shocked Big Cry
Total £267.25 + VAT = £320.70 Big Cry Shocked Big Cry
Since the LTB00110 Tech Service Bulletin states that the standard time for the sump replacement operation is 1 hour, that suggests that main dealer labour rate is now £106.20 per hour, and also that an oil change takes 50 minutes. Both of these seem a bit steep!
Also, looking at the WSM, the operation to replace the oil and filter (12.60.05) includes draining and refilling the sump, but the operation to replace the sump (12.60.44) also includes draining and refilling; so have I been charged twice for this?
Does anyone here have access to the Landrover standard repair times for these operations?
Thanks.
Post #78319 29th Jun 2011 9:07am
Happyoldgit
Chris.
Reading that takes me straight back to the '70's early '80's Laughing Steve.
http://forums.lr4x4.com
Post #78322 29th Jun 2011 9:37am
I love how you got all those cleaning products lined up in the rear window.... :mrgreen:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  QRZ 2e0vpf
Post #78336 29th Jun 2011 11:43am
Happyoldgit
GREENI wrote:
I love how you got all those cleaning products lined up in the rear window.... Mr. Green
All that's missing are the pair of Marigold's Rolling with laughter Steve.
Post #78337 29th Jun 2011 11:53am
Zag
I see you use alot of auto glym products ... I would have thought with your background that there would be some yacht hard wax that you use on your defender?
I gave my 110 a first wax with some Swiss stuff, can't remember the name but my neighbours complimented me on the shine.
I have yacht wax packed away somewhere - project for the w/e - find the yacht wax..
Post #78529 30th Jun 2011 10:11pm
WarPig
Decided to treat my Defender by getting it professionally cleaned by an expert....
Post #78537 30th Jun 2011 10:57pm
Yetiman
Well this kind of carries on from there ^^ and I know will annoy many of you Very Happy but I started prep work for a full on paint correction on the Java Black paint...swirls and scratches be gone!! Going to be a busy weekend.
She's my work truck so she needs to 'look the part'!
Cheers She's not old...just older
Post #78579 1st Jul 2011 11:13am
WarPig
Yetiman, Ive spent the last few evenings claying my Defender, and Ive got as far as waxing the roof with FinishKare FK1000P wax. Im using some Werkstat Acrylic on the rest of the bodywork.
Still got the rest to do. Fortunately I dont have any swirls to correct as its just been resprayed.
Good luck with your correction Thumbs Up Are using a machine polisher?
Post #78641 1st Jul 2011 10:00pm
TACK
Fitted the mount for the iPad and the next blue 901s gps receiver, once charged I will jail break the iPad Thumbs Up
Post #78645 1st Jul 2011 10:32pm
AndrewS
Took both the 130's off roading Thumbs Up 130's have feeling's as well you know Smile
Post #78646 1st Jul 2011 10:36pm
WarPig
Went cycling around Chatsworth House in Derbyshire with the boy
Post #78648 1st Jul 2011 10:43pm
110SEB
When you said the boy I thought you meant 'The Boy'. "F me he's lost weight" I thought before I realised you mean your boy. Happy cycling Thumbs Up
Post #78650 1st Jul 2011 10:50pm
