WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
That looks good Zagato.
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Finally fitted the noise suppressor for the CB. Not wanting to drill holes everywhere it'll still only be plugded in when I need it, but the alternator whine has gone and only a very slight amount of crackling now.
It's very much a compromised set up, but after taking another couple of mm off the bottom of the aerial, the SWR is a little lower and I managed to communicate 4.2 miles yesterday at 5lb with no interference. That's over 16x better than using the rubber duck inside the vehicle, although this was decent, in reception and transmission, but only for 1/2 a mile. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17856 ![]() ![]() ![]() |
Oil £55.84 Filter £9.98 Sump plug washer £2.60 Labour for oil change £88.50 less 20% = £70.80 ![]() Sump pan £30.90 Gasket £12.17 Labour for sump pan change £106.20 less 20% = £84.96 ![]() ![]() Total £267.25 + VAT = £320.70 ![]() ![]() ![]() Since the LTB00110 Tech Service Bulletin states that the standard time for the sump replacement operation is 1 hour, that suggests that main dealer labour rate is now £106.20 per hour, and also that an oil change takes 50 minutes. Both of these seem a bit steep! Also, looking at the WSM, the operation to replace the oil and filter (12.60.05) includes draining and refilling the sump, but the operation to replace the sump (12.60.44) also includes draining and refilling; so have I been charged twice for this? Does anyone here have access to the Landrover standard repair times for these operations? Thanks. |
Reading that takes me straight back to the '70's early '80's ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
I love how you got all those cleaning products lined up in the rear window.... :mrgreen: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
All that's missing are the pair of Marigold's ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Zag
I see you use alot of auto glym products ... I would have thought with your background that there would be some yacht hard wax that you use on your defender? I gave my 110 a first wax with some Swiss stuff, can't remember the name but my neighbours complimented me on the shine. I have yacht wax packed away somewhere - project for the w/e - find the yacht wax.. |
Decided to treat my Defender by getting it professionally cleaned by an expert....
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Yetiman Member Since: 13 Aug 2010 Location: London Posts: 138 ![]() ![]() |
Well this kind of carries on from there ^^ and I know will annoy many of you
![]() She's my work truck so she needs to 'look the part'! Cheers She's not old...just older |
Yetiman, Ive spent the last few evenings claying my Defender, and Ive got as far as waxing the roof with FinishKare FK1000P wax. Im using some Werkstat Acrylic on the rest of the bodywork.
![]() Still got the rest to do. Fortunately I dont have any swirls to correct as its just been resprayed. Good luck with your correction ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Fitted the mount for the iPad and the next blue 901s gps receiver, once charged I will jail break the iPad
Took both the 130's off roading
Went cycling around Chatsworth House in Derbyshire with the boy
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
When you said the boy I thought you meant 'The Boy'. "F me he's lost weight" I thought before I realised you mean your boy. Happy cycling
