![]() | Home > My Defender > An Anorak's Utility Station Wagon |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2308
Looks v.nice
| mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 844
Very nice.
I agree, I do my mudflaps but being that I have a 200tdi, I draw a line at the exhaust. ![]() |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
You could of course get powder coated stainless steel ones
Just wipe clean Click image to enlarge 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yeah well, I happened to have a bottle marked 'tyre dressing' so it seemed rude not to. Stainless mudflaps? Well that's a choice 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Like many, I find the standard cubby box a bit low and on previous vehicles I've fitted or made a thickly padded lid to raise it up to a more comfortable elbow height. This time though, I thought I'd take a different approach and make an extended 'lid' to make use of that bit of extra space.
I started by making a wooden tray, the same size as the top of the cubby box, comprising 45x10mm strip wood for the sides and a 9mm ply base. I then bought a blank, stainless piano hinge and drilled it out to match the existing hinge holes in the top of the cubby and let it into the bottom of the new tray. The hinge attached the original lid was then let into the top edge of the new tray so that the tray fitted between the cubby box and the lid. This way, it could all be returned to standard without having drilled any additional holes in anything. I bought a new, matching catch (Southco C3-810 Series Plastic Grabber Catch from Amazon) and fitted one half to the bottom and the other half inside the top of the tray, so that they lined up with the corresponding parts on the cubby and lid respectively. The tray has been covered with black vinyl cloth, which is an ok match for the cubby box finish, albeit newer. I was originally going to glue this on but then hit upon the idea of using double-sided tape, which was a lot more controllable and less messy! I did prime the tray to help with adhesion, which seems to have worked well. Click image to enlarge Inside, I fitted a piece of rubber matting that I had left over from another project: Click image to enlarge I'm just waiting for some thin, black Perspex to finish off the bottom: Click image to enlarge Overall, I'm really pleased. The height is now much more useable as an arm rest and I've created a bit of extra storage space, which is always a good thing! Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 376
You don't have the details of the stainless bolts somewhere do you? Planning on doing this job next week and unusually I'd like to organise all I need in advance rather than the normal procedure of getting halfway through before realising I need bits and bobs! |
Yeah, they're M8 x 50mm flanged head, purchased from eBay. Darren
| Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5895
Kill joy I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Thank you sir! Sorry Grenadier - don't fret there will be plenty of other mishaps along the way... |
Tempted by a show offer at Peterborough, I've upgraded my glove box to the version offered by Raptor Engineering. It's quite a different design to the typical kits available and also offers a lot more space:
Click image to enlarge The instructions are very straightforward, but because I'd already fitted another glove box, the early steps weren't necessary: Click image to enlarge With the old glove box removed, the only other step required in preparation was to remove two additional plastic posts from the underside of the lid, the middle one having already been cut off: Click image to enlarge The new glove box is basically folded steel sheet, so to prevent stuff rattling around inside, I lined the interior with sticky back neoprene: Click image to enlarge To fit, the whole assembly was pushed into the opening above the grab handle and secured with five supplied self-tapping screws. These each require a 1.5mm pilot hole and I drilled and fitted the rear three before drilling the front two: Click image to enlarge The lid is secured with two small Allen screws (the kit even includes the appropriate Allen key) and when all fitted, it looks very neat: Click image to enlarge Even though the front of the box is further forward, it still doesn't interfere with the grab handle: Click image to enlarge Overall, I'm very pleased. The kit was easy to fit and provides much larger and useable storage. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
That looks very smart
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3361
Looks really good.
I saw that glovebox on their website but overlooked it because the photos are so bad. |
There's a bit of deja vu with this one, as I've fitted these to my last two Defenders. The X Trouser door catch is a great little mod that significantly reduces the chances of catching belt loops on the door catch when getting into the vehicle.
Because they're not quite the same size as the originals, there's often a degree of faffing around with shims to make them fit nicely: Click image to enlarge On my last Defender, I ended up making complete new shims from plastic but it all depends on how the doors are adjusted on their hinges. This time, I only need to shim the drivers door slightly, with the passenger door not requiring anything at all. Click image to enlarge I've only done the front doors as the relative positions of the rear seats and the door frames seems to mean that it's less of an issue in the back. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
And the final little mod for today was to fit a Life Hammer. It's one of those things that you hope never to need, of course, but is absolutely the tool for the job if you do.
Positioning is tricky in the front of a Puma Defender - there are very few options and I eventually settled on the lower side of the centre dash. I did check that I could reach it with my seat belt locked before I committed myself! Fitting took five minutes and comprised three self-tapping screws into 1.5mm pilot holes: Click image to enlarge We have one fitted in my wifes' Discovery, too, but there I made a small base plate for it that, in turn, fixed to the grab handle mounting points: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
