Home > Td5 > Another Td5 with belt chirp !
Page 1 of 5 12345>
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
It’s driving me crazy!.. it’s perfectly aligned. I’ve fitted a genuine tensioner along with a new belt. I’ve tried gates and dayco branded belts, squeak free for about 100 miles then it’s starts again?
Hardly noticeable on start up, just on shut down.
It’s done 82k so I can’t imagine the crank pulley is failing?
I need to sort it.. any suggestions ?
Alex
Post #782364 21st Jul 2019 2:17pm
roel
Is it a belt or a bearing? It sounds strange that it chirps after 100 miles. Roel
2003 90 Td5 (2009-now)
Post #782365 21st Jul 2019 2:25pm
Alextd5
I’ve replaced the tensioner, so that’s a new bearing on the pulley. I haven’t renewed the idle pulley. However I can’t find a problem with with it.
I noticed when your switch off the belt jumps on the tensioner ?
I’ve removed the fan to eliminate that bearing.
It’s bloody annoying, so I need to sort it.
Post #782369 21st Jul 2019 2:34pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Not much help however mine has done this intermittently for years. Not always but once in while and still does. New belt, replaced idler, new water pump, tensioner and still the chirp??? (Not all replaced to sort the chirp just as needed) So most everything on the belt save the alternator has been replaced and its still there. Also tried it without the fan and it still happened.
Good luck Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #782378 21st Jul 2019 3:33pm
TJH1985
My 04 did this at 85k, new crankshaft pulley and it went away, only when you turn it off mind?
There was a bit of a debate about it here:
https://www.defender2.net/forum/topic65328.html
The general consensus is that they all do it, it annoyed me so I changed it.
Post #782471 21st Jul 2019 10:15pm
Alextd5
I’ve been looking online, however only britpart ones are available ? I will try Genuine tomorrow.
What did you fit ?
Post #782472 21st Jul 2019 10:20pm
TJH1985
Mine was just billed as OEM with a genuine bolt - has been fine so far.
Fitted a britpart to a friends and only annoyance was how quickly the outer bolts rusted up - purely cosmetic though.
Post #782476 21st Jul 2019 10:35pm
familymad
When you changed the belt, did you clean the pulleys super carefully? I found that I had the same issues and took the belt back off. I can’t remember what I used but something thin enough to scrape the rubber deposits from in the ribbed v bits on each pulley.
Belt back on and chirp free. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #782501 22nd Jul 2019 7:35am
Martin 01
I’m having the same problem. Only when turned off get the squeal.
Had it in to local Indy & new tensioner fitted & belt. Was ok for a couple of days but now it’s back.
The Indyhas fitted 2 different tensioner as same happens first time.
I’ll find out what make the parts where, but I know the belt is a britpart.
The squeal is annoying.
Post #782544 22nd Jul 2019 1:00pm
rallysteve
If it is squealing when turning off then it will be the crank pulley/harmonic damper that has worn out and needs changing.
Post #782545 22nd Jul 2019 1:02pm
Martin 01
Steve,
That’s great, I’ll get one ordered & replace existing. Thumbs Up
Anything good I can put on to a sqeeky clutch pedal ?
Tried white lithium grease but still bit of squeak there.
Post #782547 22nd Jul 2019 1:07pm
Alextd5
Update: I have cleaned the pulleys well and the chirp has stopped, for now anyway. I will give a further update if it reappears!
However I cannot buy a decent damper, only britpart or Genuine at £530!
Post #782605 22nd Jul 2019 6:58pm
lightning
OE parts prices are extortionate
A lot of parts shot up in price after Tata took over, for instance the TD5 Rev counter went from £85 to £300
Post #782613 22nd Jul 2019 7:20pm
rallysteve
Still eye watering but a Corteco damper from ECP is £378 currently.
Post #782615 22nd Jul 2019 7:33pm
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Almost certainly crankshaft pulley rubber breaking down. Worth changing at some point. My damper actually sheared off the from of mine! Still chirps when turning off and really need to put one I got from a breaker on it at some point... should cure it .
Post #782703 23rd Jul 2019 11:37am
Page 1 of 5 12345>
