Page 1208 of 1392 <123 ... 120712081209 ... 139013911392>
Cool Ronin Thumbs Up QRZ 2e0vpf
Post #782433 21st Jul 2019 6:41pm
Co1
Ronin wrote:
And some Elan Valley local lanes...
Lovely looking 90. 👍
Post #782440 21st Jul 2019 6:50pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Not today, but this weekend, took the family camping to Ludlow
Middle child is becoming a decent photographer
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #782531 22nd Jul 2019 11:56am
csw110
MOT time, straight through no advisories Thumbs Up Not bad for a 36 year old. Very Happy
Post #782555 22nd Jul 2019 1:54pm
williamthedog
^^^can't grumble at that then. Thumbs Up I quite like the way you covered the front number plate Rolling with laughter
Post #782584 22nd Jul 2019 5:20pm
csw110
And I've left the aircon on. Rolling with laughter
Post #782586 22nd Jul 2019 6:08pm
DG123
Great 110 csw - I bet that’s got some history Smile 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #782587 22nd Jul 2019 6:08pm
L110CDL
It sure has and is great to see in the flesh Cool Clayton.
Keeper.
Post #782650 22nd Jul 2019 9:35pm
L110CDL
GREENI wrote:
Went up in the misty hills to use some fuel and hours.
How are you getting on with this 90 GREENI Question Clayton.
Keeper.
Post #782654 22nd Jul 2019 9:50pm
Okay, thanks.
It's had a few trinkets added and some maintenance, but other than that, it's sweet as penny Thumbs Up
Getting lots of use Mr. Green QRZ 2e0vpf
Post #782715 23rd Jul 2019 1:06pm
L110CDL
Great to hear that GREENI Cool Clayton.
Keeper.
Post #782771 23rd Jul 2019 9:28pm
Had a really good day today, although very hot. Mr. Green
I fitted in (temporarily) for this time of year, a 12v 2 speed twin fan for the dogs in the rear of my 90.
It is perhaps surprisingly very good and has a near 360 degree adjustment.
Not hard wired in, simply plugs in the lighter socket and in my case zip tied on the dog guard.
Although comes with some adhesive foam pads as well.
Pretty pleased with it for £15.
Apologies for the phone pic, but you get the idea. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #782779 23rd Jul 2019 10:15pm
L110CDL
Thumbs Up Clayton.
Keeper.
Post #782792 23rd Jul 2019 10:52pm
JWL
Got round to lashing some more love and care to my 110 yesterday after sporadic sessions over the past few weeks. The whole of the suspension has been re-bushed apart from the A frame joint that I did last year and even put all new bolts on all the fixing points! New brake pads in the rear, fronts were done last year. I changed the fuel filter housing a couple of weeks ago as the old one had broken away from the chassis mounts and the fuel filter needed changing but I was loathe to set to untill I was in a position to replace the housing. Yesterday I gave her an oil and filter change and replaced the Fuel Pressure Valve gubbins with one I rebuilt with new bits. The old one wasn't suspect but I had a repair kit, the boy needed to see what was involved so I changed it and the take off one will be stored on the shelf in case it's needed under the label of a serviceable spare. I also changed the injector seals and washers, again not really needed but this is a secondhand replacement engine so I now know the state of the ancillaries.
The bummer was that, yes it started up, with a little help and patience but kept cutting out over 2000 rpm so the road test was cut short last night. This morning it was out with the spanners again and the laptop which decided that it wasn't going to open up the Nanocom programme, the boy dug out his newer laptop and downloaded the nanocom software and yep, suspicions agreed with the Nanocoms indication that the crank sensor was at fault.
When I put the replacement engine in 18 months ago we caught the wires to the CPS, did a quick repair but that seems to have let me down so today I redid the repair by digging further back into the engine loom that passes by the CPS at the back of the block and redid the wire joins to the plug.
All back together again and the jobs a good 'un. Off for a road test and a couple more turns on the turbo actuating rod has upped the boost a little and the boy was impressed with the bit of tyre squeal that can be had at junctions Whistle
Post #783164 25th Jul 2019 11:22pm
ericvv
This weeks heatwave is good occasion to see if the A/C properly functions. And to check if the little bung under the gearbox is not blocked. All is good, yesterday in the city in 39°C, air from vents was nicely ice cold and a steady stream of condensation water was spilling down onto the ground over the middle crossmember.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #783212 26th Jul 2019 10:44am
