Home > Puma (Tdci) > Tips for installing silicon intercooler hoses? |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
I didn't find mine (from BAS) too bad to do. My 2.2 doesn't have aircon which makes it a bit easier.
Getting the airbox out is a faff, but taking out the right hand headlamp makes access to the lugs on it easier. The most challenging hose is the short elbow from the inlet manifold on the left hand side to the steel hose that then joins to the intercooler with another longer flexible hose. Some folks leave it out, but as it's the one most likely to split, I think that's not a good idea. You'll destroy your arms on the water hose spring clips, but I managed that elbow in around an hour and a quarter, considerably helped by using a flexible Jubilee clip tool: https://smile.amazon.co.uk/gp/product/B000...&psc=1 There are some hard rubber spacers on the water hoses on the left hand side and I found sliding these away from where you're working helped to give me a bit more space. You'll also need to unclip the hoses from themselves and the bodywork in several spots to help access. Unbolt the steel pipe from the water pump (two long bolts, awkward, but do-able with a socket wrench and ring spanner) partly using the larger space between two of the fan blades (have a look, there's a couple of larger gaps) for access. There was no need to remove the water pump as has been suggested elsewhere. Once you've got the old elbow off, use a bit of soap to lubricate the inside of the large end of the new elbow and jiggle it onto the inlet manifold. It's a right blighter and be careful not to dent your wing. Loosely tighten the clip (I used new stainless genuine Jubilee clips) and then you can get the end of the steel pipe pushed into it. Again, a bit of soap helps. You will need a lot of force and a lot of swearing to do this. Once you've re-tightened the two bolts for the steel pipe, you can tighten the two Jubilee clips up on the elbow with the flexible tool. Note that the clips will (obviously) go on two ways but you'll find you can only reach to tighten them if fitted one particular way. It should be obvious once you start. Make sure you've got both clips onto the elbow before you try to re-fit the steel pipe. The two longer pipes aren't too bad to do, but you will need to remove some bits to get to them. You don't need to re-fit the coiled steel protector on the right hand one, but you do need to re-clamp it to the alternator using the original clamp. You'll think the clamp is too small to suit the new hose, but it will go on. If you haven't got this clamp, it was a LR mod from around 2014 to stop the hose chafing through. If you've bought the BAS kit, the right hand hose will need a bit (15 - 20mm) removing from the turbo end. I used a new blade in a Stanley knife for this. Instructions are included, but don't take too much off. There was a lot more stuff about this on here, but sadly most of it disappeared recently. I hope this is a bit of help. |
11th Jul 2019 7:16am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2231 |
Check your first aid kit for availability of plasters > 110 XS Double Cab > Instagram @simonlanemind |
11th Jul 2019 7:21am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19574 |
And antiseptic cream.
What's the best tool for the spring clips on some hoses too? They were a right pain when I had to change my waterpump! Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
11th Jul 2019 10:06am |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
either long nose pliers or buy yourself a proper set of clip pliers.
The above advice about the fitment of the pipes is pretty spot on, me and sulisuli fought the little elbow one for a couple hours then took the metal pipe off the water pump and had it on and buttoned up in half an hour. just make sure you have the circ-clips on the pipes square and the pipes on far enough so that they get a proper grip above the lips on the pipes as they can slip off when somebody is booting it up the motorway and you have to go and put the pipe back on twenty miles away 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
11th Jul 2019 10:12am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3616 |
Epic advice Joe, very much appreciated!! |
11th Jul 2019 1:18pm |
I did mine without removing anything. Took around half an hour but I did look like I had been dragged through a rose garden > 110 XS Double Cab
11th Jul 2019 1:38pm |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 |
I did mine last weekend, and took a " it will take as long as it takes approach" I still came away with battle scars though.
The only thing I struggled with was the air box removal, as it was well stuck in its rubbers. Plenty of wiggling and wd40 in the end. I wish I had thought of taking the headlight out though - great tip. I do recommend buying new hose clips though. |
11th Jul 2019 3:20pm |
You can drill the rivets out of the air box from under the arch, just be careful you don't go too far though and have replacement rivets.
Once they are drilled out and the other other pipework removed it'll pull straight out. The replacement rivets have a wide flange head for spreading load. You then don't have that airbox rubber issue. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
11th Jul 2019 4:41pm |
Airbox comes out easy if you don’t have aircon. If you do it’s a PITA no matter what way you try and do it unless you disconnect the aircon pipe. Which is ever so slightly illegal if you have the gas in the system. You’ll also need to get your aircon system leak checked and re gased afterwards. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
11th Jul 2019 6:05pm |
I removed the expanded ends of the airbox fixing lugs so that it still uses the remaining stubs but isn't as firmly fixed as it was originally. I've had no problems with it working loose so far (the silicone airbox to turbo hose helps...) and it's now much easier to remove if I need to.
For spring clips, I use my water pump pliers. They're not designed for it, but work a treat and have plenty of leverage to hold the clips open. Mine are made by Ridgid and if you can afford them, they're useful for no end of things apart from plumbing. These are the ones I use: https://www.cromwell.co.uk/shop/hand-tools...IG5648047E The ones shown above are mine, but the same ones on Amazon have a different picture for some reason. |
11th Jul 2019 7:45pm |
stevec205gti Member Since: 31 Jul 2018 Location: Nr Cambridge Posts: 24 |
This could be the best £8 you ever spend.... https://www.ebay.co.uk/itm/Flexible-Long-R...SwQaFawxSr I've not had to fiddle with any hoses on my Defender yet, but these have been amazing on previous land rovers. Simply feed the head over the clip, squeeze the handle, and they lock the clip open so you can slide it out the way. |
12th Jul 2019 7:18am |
Hoses arrived today, but I think they are wrong? Ordered hoses for a 2013 2.2 tdci which I think are the hose one the left, but then one long hose instead of the two short pieces. Am I missing a trick here?
Click image to enlarge |
12th Jul 2019 7:35pm |
Is that all you received? 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
12th Jul 2019 7:41pm |
Yep, that was the lot!
12th Jul 2019 7:44pm |
