Home > Puma (Tdci) > Tips for installing silicon intercooler hoses?
Page 2 of 3 <123>
Co1
Just checked and I ordered the TF742, but should have ordered TF742late.
Post #781278 12th Jul 2019 7:46pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Doh Embarassed 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #781280 12th Jul 2019 8:01pm
Roy5695
The late kit doesn’t seem to contain the little 90degree elbow off the manifold though. Which is prone to splitting in the 2.2s
I’d personally be buying from BAS or Alive. More expensive but well made and fit properly. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #781282 12th Jul 2019 8:05pm
Co1
I’ll fix it with beer tonight and sort it next week.
Post #781286 12th Jul 2019 8:14pm
familymad
We had hot soapy water and the hoses in there before fitting. They were much easier to fit and malleable after it. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #781339 13th Jul 2019 1:44pm
Co1
Picked up the right hoses today from trek overland. Just replaced the damaged one and skinned all my knuckles. Wish I’d read about the hot water thing before!!
Post #781340 13th Jul 2019 1:47pm
hank
Welcome to the club Thumbs Up > 110 XS Double Cab
Post #781345 13th Jul 2019 3:09pm
Co1
Did the other side this morning. Marked out 2 hours but it took 30mins! The air box came out nice and easy, as did the old hose. New hose slipped on nicely and everything went back together well. I’m off to buy a lottery ticket!!
Post #781438 14th Jul 2019 12:12pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Have you done the elbow off the inlet manifold? That's the most difficult but unfortunately also the most prone to splitting.
Post #781440 14th Jul 2019 12:24pm
Co1
Yep. No problems at all!
Post #781441 14th Jul 2019 12:38pm
Sulisuli
Changing these hoses if you do the 90* elbow as well is a bit like the LOF clutch pedal spring it can go well for some but not as well for others Rolling with laughter good job well done Co1. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #781445 14th Jul 2019 1:32pm
hank
So the 2.2 has a silicone elbow off the turbo where the 2.4 has a rigid plastic? > 110 XS Double Cab
Post #781446 14th Jul 2019 1:34pm
Joe the Plumber
The elbow I was referring to is the one low down on the left hand side of the engine, not from the turbo.
I was under the impression that the hoses were the same on both engines, but I only have the 2.2 to look at so apologies if I'm mistaken
Post #781452 14th Jul 2019 2:30pm
Co1
I paid my dues and then some with the Lof pedal spring, so this is payback!
Post #781454 14th Jul 2019 2:43pm
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
Need to do my hoses but not sure on this late early thing mines 2013, need 3 pieces from what i can see
1 turbo to intercooler 2 intercooler to pipe with air sensor in it and 3 the elbow to throttle housing. BAS picture looks right but they have only one type?
Post #782083 19th Jul 2019 1:54pm
Page 2 of 3 <123>
