Home > Puma (Tdci) > Tips for installing silicon intercooler hoses? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3618 |
Just checked and I ordered the TF742, but should have ordered TF742late.
12th Jul 2019 7:46pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Doh 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
12th Jul 2019 8:01pm |
The late kit doesn’t seem to contain the little 90degree elbow off the manifold though. Which is prone to splitting in the 2.2s
I’d personally be buying from BAS or Alive. More expensive but well made and fit properly. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
12th Jul 2019 8:05pm |
I’ll fix it with beer tonight and sort it next week.
12th Jul 2019 8:14pm |
Picked up the right hoses today from trek overland. Just replaced the damaged one and skinned all my knuckles. Wish I’d read about the hot water thing before!!
Click image to enlarge |
13th Jul 2019 1:47pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2233 |
Welcome to the club > 110 XS Double Cab
> Instagram @simonlanemind |
13th Jul 2019 3:09pm |
Did the other side this morning. Marked out 2 hours but it took 30mins! The air box came out nice and easy, as did the old hose. New hose slipped on nicely and everything went back together well. I’m off to buy a lottery ticket!!
14th Jul 2019 12:12pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Have you done the elbow off the inlet manifold? That's the most difficult but unfortunately also the most prone to splitting.
14th Jul 2019 12:24pm |
Yep. No problems at all!
14th Jul 2019 12:38pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Changing these hoses if you do the 90* elbow as well is a bit like the LOF clutch pedal spring it can go well for some but not as well for others good job well done Co1. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
14th Jul 2019 1:32pm |
So the 2.2 has a silicone elbow off the turbo where the 2.4 has a rigid plastic? > 110 XS Double Cab
14th Jul 2019 1:34pm |
The elbow I was referring to is the one low down on the left hand side of the engine, not from the turbo.
I was under the impression that the hoses were the same on both engines, but I only have the 2.2 to look at so apologies if I'm mistaken . |
14th Jul 2019 2:30pm |
I paid my dues and then some with the Lof pedal spring, so this is payback!
14th Jul 2019 2:43pm |
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 103 |
Need to do my hoses but not sure on this late early thing mines 2013, need 3 pieces from what i can see
1 turbo to intercooler 2 intercooler to pipe with air sensor in it and 3 the elbow to throttle housing. BAS picture looks right but they have only one type? |
19th Jul 2019 1:54pm |
