![]() | Home > Puma (Tdci) > Tips for installing silicon intercooler hoses? |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3787
Just checked and I ordered the TF742, but should have ordered TF742late.
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
Doh
Instagram - @r22oyp Roy |
The late kit doesn’t seem to contain the little 90degree elbow off the manifold though. Which is prone to splitting in the 2.2s
I’d personally be buying from BAS or Alive. More expensive but well made and fit properly. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
I’ll fix it with beer tonight and sort it next week.
Picked up the right hoses today from trek overland. Just replaced the damaged one and skinned all my knuckles. Wish I’d read about the hot water thing before!!
Click image to enlarge |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
Welcome to the club
Did the other side this morning. Marked out 2 hours but it took 30mins! The air box came out nice and easy, as did the old hose. New hose slipped on nicely and everything went back together well. I’m off to buy a lottery ticket!!
| Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921
Have you done the elbow off the inlet manifold? That's the most difficult but unfortunately also the most prone to splitting.
Yep. No problems at all!
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Changing these hoses if you do the 90* elbow as well is a bit like the LOF clutch pedal spring it can go well for some but not as well for others
2008 SVX 90 2000 XS TD5 90 |
So the 2.2 has a silicone elbow off the turbo where the 2.4 has a rigid plastic? > 110 XS Double Cab
The elbow I was referring to is the one low down on the left hand side of the engine, not from the turbo.
I was under the impression that the hoses were the same on both engines, but I only have the 2.2 to look at so apologies if I'm mistaken . |
I paid my dues and then some with the Lof pedal spring, so this is payback!
| Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 106
Need to do my hoses but not sure on this late early thing mines 2013, need 3 pieces from what i can see
1 turbo to intercooler 2 intercooler to pipe with air sensor in it and 3 the elbow to throttle housing. BAS picture looks right but they have only one type? |
| All times are GMT |
