![]() | Home > Td5 > TD5 shuts off in Traffic and won't start. |
check earthing i.e. start at battery neg make shore sound
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
Earth to fuses and relay in underseat box?
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 672 ![]() ![]() ![]() |
Check battery voltage, in case of not correctly working alternator, and battery discharged with running engine instead of charging it. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
I had a problem like that. Unplugging and plugging back in the black plug helpt me to restart it everytime. I cleaned both plugs (no oil) and made an additional earth from the ecu housing to the battery negative. No problems after that ( more than a year) Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
stevejohns72 Member Since: 09 Sep 2013 Location: Monrovia, Liberia Posts: 16 ![]() |
Thanks guys for the valuable input. I tried all the various suggestions, but finally narrowed it down to a faulty ECU. I sent the ECU to a company in the UK called ECUTESTING. They repaired it and sent it back to me.
My Defender is back on the road again with increased power output. ![]() |
