![]() | Home > Puma (Tdci) > Puma 2.4 hesitating & cutting out. |
Tomotomo Member Since: 13 Feb 2018 Location: Bucks Posts: 71 ![]() ![]() |
If you have access to diagnostics. I would start checking the obvious things like fuel rail pressure actual vs desired.
Still sounds fuel related to me. You could do injector relearn as well. If that fails perhaps you have a suspect one. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Whats the max difference between desired and actual rail pressure? Puma 110" SW
DavyG Member Since: 23 Jun 2019 Location: Ireland Posts: 10 ![]() ![]() |
Cured. Injectors removed and sent off for testing. 2 failed and were replaced. Pilot re-lrelearn carried out and now running sweet.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21020 ![]() ![]() |
Glad it's solved.
![]() This is why I run the millers diesel additive to keep everything as clean as you can hope for, I try and stick to the same fuel where possible too as some of it can cause poor running I've found. Especially if you have a tune. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 7th Jul 2019 2:00pm. Edited 1 time in total |
Excellent, π
