![]() | Home > Puma (Tdci) > Puma 2.4 hesitating & cutting out. |
Diffy Member Since: 04 Oct 2015 Location: Taunton Posts: 6 ![]() ![]() ![]() |
I had very similar symptoms- was water in fuel filter from perished tank breather hose - and from this a knackered VCV
As said above, try changing the vcv valve. Easy enough to do. You're supposed to do a pump relearn after changing but they'll run fine without doing.
DavyG Member Since: 23 Jun 2019 Location: Ireland Posts: 10 ![]() ![]() |
Cheers guys...I've been doing a lot of "googling" this morning both on the puma and transit forums. It seems that it could be a faulty VCV, SCV or PRV or a combination of all three. Some advise to replace all 3, as they do and will fail at some point.
Again....any advice is welcome. Regards, DG |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
You should be okay with changing VCV only. Mine needs doing really. And fuel tank breathers as suggested. Hoping the latter isn’t an overly expensive job to get done. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Quick update...
Dropped the fuel tank today ![]() |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 783 ![]() ![]() ![]() |
Clean and dry out the tank before re-fitting and re-filling. You've already changed out the fuel filter, so that's good. Check that the fuel filter is seated properly and wobbling when tightly fitted.
Changing the VCV is good since you said you had sludge in the tank. You'll have to do the pilot correction and pump re-learn after you replace the VCV to ensure smoother operation. Since you already have the PRV, I guess it couldn't hurt to replace it as well if it was suspect. |
I thought you could change the VCV without relearn and eventually it will do it, it’s self. ____\We|Will|Win/___
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285 ![]() ![]() ![]() |
Always worth unplugging the MAF sensor, I had all kinds of issues with cutting out, unplugging it will cause it to just run default values. On mine it stopped all the issues, then I just fitted a replacement and no more problems.
I was not getting any lights or alarms or codes. Just cutting out and poor running. 2008 Defender 110 XS CSW Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
Today’s latest...
VCV (SCV) & PRV FITTED. Now ticking over perfectly but still hesitating and losing all power when driven. Would an ECU re-learn be the problem now? Slowly losing the will to live.... ![]() Regards, DG |
Tomotomo Member Since: 13 Feb 2018 Location: Bucks Posts: 71 ![]() ![]() |
Did it carry out the full 're learn without problem?
Mine did what you describe, there was still some air in fuel line. Have you checked drain screw and filter properly on. |
I haven't had it plugged in to diagnostics yet....I thought it would have ran ok without much issue.
You could, but things would be smooth sailing quicker if you could do the relearn after replacing the VCV. Since he's still experiencing cut off issues, having the OBD scan tool plugged in can help him monitor the values to see if there is anything else he should be checking. |
👍🏻 ____\We|Will|Win/___
The latest...PCM re-learn completed. No faults stored or showing. Now idling without cutting out. Still a very bad hesitation while driving, with a loss of power. Unplugged the MAP sensor and took it for a drive...loss of power. Disconnected the MAF sensor...made no difference.
Any ideas...? Regards, DG |
